I'm was looking at the analog pre-amp-out circuit board on my receiver (Denon AVR-3805) and noticed that the signal passes through two electrolytic capacitors before it reaches each RCA jack.
These caps are prime to upgrade obviously, but here's my question: The stock caps are 22mf/50v polarized caps, as you can see on the attached schematic. Can I replace these with non-polarized 22mf Blackgate electrolytics, or is there reason the stock ones are polarized? -Bryan |
#2 |
Electrically, yes you can use them.
Bipolar electrolytics are actually two electrolytic capacitors connected in series in one case. So, instead of 1 22uF cap, you're putting in 2 44uF caps in series (which divides the effective capacitance but protects both caps from reveresed polarity). I would say to bypass such a coupling cap with a good quality foil cap (.1 uF or so). i.e. Put in the bipolars, but also put a .1uF Wima or something in parallel with each of them. |
#3 | |
Martin Rupp |
#4 |
NP caps block DC while polarized ones pass it.
What I was hinting at was whether this type of circuit actually requires polarized caps...and if switching to NP versions could cause some instability in the circuit. |
#5 | |
Non-polarized caps can take DC offset in either direction. Polarized caps can take it in one direction only. If you take your 22uF 50V NP's, you can apply, for example, +35V to one leg and ground to other, or vice versa, and in either case things will be just fine. If you try the same thing with a polarized cap, things will only be fine with +35V on the + leg. If you reverse it, the cap will start to get hot, and will eventually vent or explode. |
#6 |
Thanks for the info, I didn't know NPs could pass DC, explains some things about modding that never seemed to click with me. Time to order some Blackgates....
| Polarized to non-polar capacitor wiring | mjarve | Parts | 8 | 2nd April 2012 03:27 PM |
| Black Gate Standard Polarized or PK Mini Polarized = Rubicon YK or YXE | kurtbauer | Parts | 1 | 21st August 2008 06:50 AM |
| Where can I buy Blackgates??? | K-amps | Parts | 3 | 25th February 2005 01:07 AM |
| Do Blackgates age? | ainami | Parts | 4 | 10th January 2005 10:34 AM |
| Can I make a Non-Polar Electrolytic using two polar ones | PaulHilgeman | Parts | 6 | 10th February 2003 12:07 AM |
| Page generated in 0.10745 seconds (73.55% PHP - 26.45% MySQL) with 11 queries |
