Old 4th February 2009, 12:29 PM   #1
Default Gain evaluation of a preampli stage
Please, can somebody help me to evaluate the gain of the preamplifier stage figured in the attached image?
If yes, how?
Thank you very much.
Old 4th February 2009, 02:42 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
Looks like some RIAA Phono.
Which means that the gain is different at different freq.
What the gain is at 1 kHz, nominal, I can not say.
Shuold be possible to run in spice simulator, to find out.
And get the AC Analysis frequency/gain curve.
lineup
Old 4th February 2009, 03:10 PM   #3
Oh, this is certainly a line preamplifier stage, in fact this stage follows the volume control in a Marantz PM78 integrated amplifier. This means that is a strictly flat preamplifier.
Thanks however.
Old 4th February 2009, 03:54 PM   #4
Andypairo's Avatar
At a quick glance the AC gain seems to depend mostly on the ratio between the 2k2 resistor and the series of 270Ohm+1K trimmer, so it can be adjusted in from slightly less than 2 to slightly less than 10.
Ciao
Andrea
I don't believe in audiophile components - except when I can get them at frugal-phile(tm) prices
Old 4th February 2009, 03:59 PM   #5
lineup's Avatar
Ok.
Gain between 2 an 10 for line amplifier makes sense.
Adjustable with the pot.
lineup
Old 4th February 2009, 04:00 PM   #6
analog_sa's Avatar
Goodness gracious. Another spice junkie?
Old 4th February 2009, 04:01 PM   #7
lineup's Avatar
Don't you have Spice, analog_sa
Where have you been last 10 years
lineup
Old 4th February 2009, 06:55 PM   #8
mjf is offline mjf  Austria
hello.
quick estimated: (2.2div0.27)+1=8 high gain
and (2.2:1.27)+1=1.7 x lowest gain...
greetings...........
Old 4th February 2009, 08:28 PM   #9
That's all, thank you very much!
New gain stage .. Opinions??? nitrate Tubes / Valves 4 26th January 2009 01:02 PM
Gain stage with g2-feedback. jane Tubes / Valves 18 28th May 2008 09:06 AM
Simple 12v gain stage dublin78 Solid State 10 14th April 2008 03:37 PM
Output stage with gain rtarbell Solid State 18 27th October 2006 07:15 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
Page generated in 0.09657 seconds (78.56% PHP - 21.44% MySQL) with 11 queries
