Just ask in normaly for power mosfet, how many mA of bias to set? I have adjusted at 150mA, but it seem too hot.
Can anybody help me, thank in advance. |
#2 |
Mosfets? Bias them as high as you can afford.
These parts do not have a current at which crossover distortion is minimized (as it is the case for BJTs). Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets F5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#3 |
150mA - 200mA is quite normal for standard power amp output.
If 'only' 150mA makes too hot, then you have either some other problem (like instability/oscillation) or your heatsink is way too small.
lineup |
#4 | |
Just because you can't hear it doesn't mean no one can. |
#5 |
Borbely recommends a minimum 150mA through each Output FET and a minimum of a total 500mA through all the parallel output FETs.
He only designs and builds FET amplifiers and ancilliary gear. Some good design papers on his website.
regards Andrew T. |
#6 |
Thank above, I will check and try.
#7 | |
the temperature of a normal 140mm width heat sink will probably up to 130~140¡¦F and it is too hot. So I ...
EuLeit Audio Studio one of the best hi-end Amp design house in Taiwan http://www.euleitaudio.com |
#8 |
Use two heat sinks for 2 pairs power mosfet, and hope can get >250mA
bias current for each at normal temperature. (+/-32.5V 500mA is just for testing, other 70mA is for the Relays.)
#9 |
It doesn't make sense : if you use a heatsink the size of the one in the picture, at idling the temperature should be max 100°F with 250mA.
What does your dissipation calculation says? If it's way too hot, there must be some HF ringing or so. It's just calculations, they don't lie. Regards |
| bias voltage vs bias current | woodturner-fran | Tubes / Valves | 3 | 24th February 2007 11:24 PM |
| bias circuit for mosfet help | AudioGeek | Solid State | 2 | 29th April 2006 11:22 PM |
| LTP bias current | cunningham | Solid State | 2 | 12th January 2005 08:39 PM |
| BOSOZ MOSFET Bias | DavidMM | Pass Labs | 1 | 12th November 2002 05:16 PM |
| BOZ Bias Current | gema | Pass Labs | 2 | 20th February 2002 07:28 PM |
| Page generated in 0.11292 seconds (78.20% PHP - 21.80% MySQL) with 11 queries |
