Attenuator BEFORE or AFTER active crossover?
Old 3rd February 2009, 10:16 AM   #1
Groundloops is offline Groundloops
Im amazed!
Groundloops's Avatar
Question Attenuator BEFORE or AFTER active crossover?
Is there any benefit of having the volume control potentiometer after an active crossover?
My thought: Usually active crossovers are fed by a preamplifier, so the signal levels of source devices are attenuated if the volume control isnt cranked up to stop collar. In that case the active crossover handles very low signals and SNR is not ideal.
Feeding an active crossover with full signal level would increase SNR. Only drawback is that a multi-ganged potentiometer (4-ganged for 2-way stereo, 6-ganged for 3-way stereo etc.) and equivalent number of output buffers are needed.
Do I suppose right?
Old 3rd February 2009, 10:57 AM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Yes, but in practice it's not that bad to have the volume control before the active crossover.
I use to feel like the small child in The Emperor's New Clothes tale
Old 3rd February 2009, 03:12 PM   #3
Im amazed!
I think so too in general, but how bad is 'not that bad'?
Old 3rd February 2009, 05:32 PM   #4
I used a dual track volume pot before the pair of two way active crossovers.
I was surprised at the increase in noise level at the speakers.
I redid all the R & Cs to lower impedances, but found only a small reduction in noise.
I have since reduced the gain of those power amps and the noise improved yet again but still not satisfactory.
The active crossover was all unity gain using opa275.
Unacceptable in my view.
regards Andrew T.
Old 3rd February 2009, 06:50 PM   #5
adason is offline adason  United States
adason's Avatar
Good question SmellOfPoo,
I am using active 2way crossover to split the signal for two subwoofers and the satelites. Since I am using two different amps, solid state for subwoofers and tube for satelites, volume control on each amp after the crossover is a neccasity, since the amps have different gain and speakers different sensitivity.
I played around with volumes on amps turned lower and master volume higher up ...vs one amp all the way up, the other one lower to compensate, with master volume much lower....well, I did not found much difference in noise performance overal, since my crossover is just two buffers and passive split.
I belive the difference will be audible if only a poor active crossover is used, like for car or something.
Old 4th February 2009, 12:45 AM   #6
Michael Chua is offline Michael Chua  United States
Michael Chua's Avatar
In PA/Pro crossovers, its common to have one at the input and one at the output.
The Input is meant to adjust your gain. You would want to adjust the signal running through the crossover to be as "hot" as possible without clipping.
At the Output, it is usually a Line driving amp. It can be Unity or with modest gain. This will allow the user to control the volume out to the amplifiers.
If your amplifiers have gain controls at the inputs, you may want to do away with the output volume at the crossover. Most Hi-fi amps do not, so there's no other way but to have volume controls at the outputs of the crossovers.
Not sure I'm following you here. You only need 2-ganged pots in a stereo crossover. Doesn't matter whether its 2,3 or 4-way. Every output is 2-ganged. You don't control overall volume at the crossover. It's done either at the mixer or your Pre-amp.
Mike
ampslab
Old 4th February 2009, 12:59 AM   #7
Originally posted by Andrew T
I used a dual track volume pot before the pair of two way active crossovers. I was surprised at the increase in noise level at the speakers. I redid all the R & Cs to lower impedances, but found only a small reduction in noise. I have since reduced the gain of those power amps and the noise improved yet again but still not satisfactory. The active crossover was all unity gain using opa275. Unacceptable in my view.
Hi Andrew
That's a bit strange. It should be very quiet if they are at unity gain.
Have you tried running the Preamp direct into the crossover and transfer the volume pots to the outputs (passive) followed by a Buffer?
Mike
ampslab
Old 4th February 2009, 09:33 AM   #8
Im amazed!
Maybe I should sketch my proposal: Im about building a sort of 'all in one monster receiver' because I dont want to have a rack full with stacks of cases any longer. Tuner, DAC, 2 3-way active crossovers and 6 mono amps combined in one enclosure, each with separate transformer and PSU. Yes, its gonna be huge, heavy and maybe beastly. Proper shielding and grounding maybe a challenge too.
My idea is that tuner, DAC and 3 miscellaneous input signals pass a selector switch, go into a buffer, then into 3-way crossover, followed by 6-ganged attenuator (3*2 channels), 6 (3*2) buffers and finally into the amps. Possible gain differences between the amps (SymAsym for low and mid, LM3875 GainClone for high) are equalized by simple voltage dividers on the amps inputs.
So the signals would run on full level all the way until the attenuator.
Will I achieve that in the way I described? Forgive me if my exposure isnt clear, Im no native english speaker.
Old 4th February 2009, 11:17 AM   #9
agreed a bit strange. I didn't expect using 100nF and 10k to cause a noise problem with +34dB amp and 86dB speakers. But it does. 200nF & 5k into +28dB amp and 86dB speakers is better but still not acceptable.
I haven't tried my 90dB or 94dB speakers in this arrangement.
I have not tried using discrete buffers either side of the crossovers/pots.
Dual track pots before the crossovers is much more convenient than 4 or 6track pots after the crossover. That convenience has a consequence.
regards Andrew T.
Old 4th February 2009, 11:49 AM   #10
forr is offline forr  France
forr's Avatar
Here are some pictures of one of the best installations in France.
http://www.cinetson.org/phpBB3/haut-...ile-t9877.html
All to have an extremly high overall definition.
His owner, THXRD, has compared both solutions for the attenuator :
N/A converter of the digital source --> two channels attenuator --> A/N converter of the speaker processor --> N/A converter of the speaker processor --> power amplifiers
and
N of digital source --> N of the digital processor --> N/A converter of the digital processor --> six channels attenuator --> power amplifiers
He did'nt notice any change despite the more many stages included in the first scheme.
I did the same and did not agree until I got a much better N/A for the digital source. My speaker processor is a BSS366. The volume control before it is much more handy.
My 6 ways / 6 positions stepped attenuator (-10 to -60 dB) is still in the circuit at the -10 dB position. A -14 dB attenuation would be preferable I think, the voltage gain of the power amplifiers being about 30 dB.
Attenuator BEFORE or AFTER active crossover?Hide this!Advertise here!
active crossover: fir vs iir netchris Everything Else 3 29th July 2008 10:14 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 07:16 PM
6x ladder attenuator on active system aaronboumans Pass Labs 1 24th February 2005 09:56 AM
(LONG!)Crossover Design - 2nd Order Butterworth with attenuator GeniX Multi-Way 2 22nd October 2002 12:03 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 02:29 AM
Copyright ©1999-2017 diyAudio
