2SB552 & 2SD552 Applications
Ciao e tutti!
Genuine Toshi. 2SB552 & 2SD552 complimentary
I used to use these devices extensively consequently I have a large number of them lazily sitting round on heatsinks & in packs just gathering dust.
Anybody know of a really nice power-amp that I could build to use them up?
Pip pip
Ciao e tutti!
Pip pip
57 years oldtimer .....
line up ..... you should know to look for 2SB552.... and so on ....
chris ......with devices like the above you can built anything you want ....
you may produce amps from 40 -500 w easily
i think that they are very nice outputs
how many you have????? and what is the chance that i get some of them ?????
i am willing to pay or trade
thanks
thanks
chrisnotton said:use them
Beta of those Toshiba TO3's already starts to drop like a fly at a low collector output current level, much earlier than Motorola TO3 numbers.
Means any design with a triple darlington output stage, and plenty power devices in parallel.
Re: 57 years oldtimer .....
you are right
My problem was that I searched for SB552
and not 2SB552
sakis said:line up ..... you should know to look for 2SB552.... and so on ....
you are right
and not 2SB552
lineup said:Are you sure about
Toshiba SB552 and SD552
I can not find those
Here you go lineup
http://www.datasheetarchive.com/2SB552-datasheet.html
http://www.datasheetarchive.com/2SD552-datasheet.html
The devices I have are mounted on large heatsinks. There is 15 of each per heatsink used to drive 3 motors swinginging them between +/- 40VDC from a 20A supply.
The file seems to be too big to upload so here is a link to the circuit: http://snipurl.com/b80pr
I don't know how well the circuit would work as an audio amp. Needs abit of d.c. protection
Pip pip
- 2SB552 & 2SD552 Applications
