come acroos this sears amplifier that i actually restore and upgrade with in the possible .....
rewiring a few things here and a few things there i realized that this amplifier features a feedback trace with a piece of wire directly from binding post in the out put connectors ( ???? ) pretty fancy i thing for a comercial korean amp . in the outsi normaly like to keep seperated leads from the amplifier boards till the output connections also i like to twist them with another seperated lead coming from signal star ground .... so i have one twisted pair from each output to each connector .... Question ???? what happens then to feedback trace ????previously all of these cables like rails input output feedback and so on were just simply straped on all together .... do you thing that its ok to twist 3 cables like one signal one ground and one feedback ????
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#2 |
thats odd .....
#3 |
I donīt understand what you are talking about. Could you explain a bit more?
#4 | |
most ab class amps need feedback thats a trace that comes from the output through a resistor to the base of the second transistor of ltp stage ..... in some amps this trace comes not from the output on the pcb area but directly from the speakers connections .... similar to this if i remember well was the Ó drive amps from kenwood that used seperated connectors to do the same thing in order to take feedback directly from the speaker connection on the speaker box the question remains : if twisting one signal one ground and one feedback canble will have any effect ( for example it is known that twisting the rail cables from psu board to amplifier board is a good thing to do as long as you are not twisting ground with them ........ for the output leads is the oposite ....twisting L out cable with ground and sent it from amplifier board to ouput connectors while you try to keep it as far away is possible from rail cables or Rout lead )
| Strange feedback method | hotbottle | Tubes / Valves | 4 | 12th April 2008 09:38 PM |
| strange feedback | Clipped | Car Audio | 3 | 21st February 2008 08:59 PM |
| Strange biasing issue when adjusting VBE | EWorkshop1708 | Solid State | 30 | 6th July 2005 05:17 AM |
| Strange Wiring in Bogen 6v6 PP | zxx123 | Tubes / Valves | 23 | 3rd February 2005 06:07 PM |
| Strange Humming issue...could it be? | NewbieChipGuy | Chip Amps | 2 | 3rd March 2004 02:55 AM |
| Page generated in 0.08883 seconds (70.22% PHP - 29.78% MySQL) with 10 queries |
