ROTEL amp sounds dull
Old 15th February 2009, 08:55 AM   #21
Chris Babineau is offline Chris Babineau  United States
Emitter resistors as far as I know are always some fraction of an Ohm i.e. .47 .22. Most ohm meters don't do a good job measuring a fraction of an ohm. But if a basic meter is all you have you could lift one end of the resistor in question and compare the value to some of the other emitter resistors (also with an end lifted) and if the discolored one is different than it should be replaced. The associated transistor may have been stressed and possibly should be checked as well.
An emitter resistor is like a current sense and helps balance out the load with parallel power transistors. Some call this "current hogging".
Old 15th February 2009, 09:18 AM   #22
homemodder is offline homemodder  Portugal
The resistors are not wirewounds, with the inductance of wirewounds the amp would oscillate, they should have been of a higher power rating, they do not drift because of time but because of high power usage into difficult loads, speakers can dip into 2 ohm load at some frequencies. They are only rated to 2 watt which is a low for the power rating.
The weak link in rotel is always the preamp section, the amp itself is pretty good.
Old 17th February 2009, 12:14 PM   #23
carlmart is online now carlmart  Brazil
Originally posted by Bartt
I adjusted the bias and what a difference!! It's sounds so much better! The only thing is that one of the emittor resistors looks a bit black. I checked it and they all seem to be 0 ohm on my multimeter but on they should be 0,22 Ohm K (that's 220 Ohm?). So are they all burnt? On them is written: "MPC70 0.22 Ohm K fil 2502".
That's a 2watt wirewound resistor indeed. Definitely a bit low on wattage if the load is difficult. Going up to 5watt would be safer.
Whether it's bad to be wirewound or not may be arguable. I think a non-ww resistor could sound better, and nowadays you can find them pretty affordable.
If one resistor is black it may be dirt or maybe burnt. Replace it. If you fill courageous go to a lower resistor, like 0.1 or o.15: it may also improve the audio quality.
Also change the bias trimpot and put a multi-turn type. Take note what value the Rotel one is set for, and set that on the multi-turn to start testing.
Also the bias seems to drift. When I set it at 10 mV it 'll be 20 or so in a while and next time I switch it's different as wel, though it won't get past 25 mV or so. Left and right are different (like 5-10mV difference). Is that a problem?
Can you tell me how the Rotel keeps bias stable? That diode/transistor should be in contact with the heatsink or an output transistor. It should be physically in contact with that. Being that alright, a drift, until temp stabilizes, is normal.
And about the caps: I ve seen lots of brands on the internet. What would be a good choice in my amp? What about these: Nichicon Muse KG 10000uf 63v at 90 euro? I couldn't find any at digikey btw.
Digikey does not sell Muse, AFAIK. They have Panasonic and Philips, if I remember well, which are also good. If you live in Europe and want to change capacitors buy Siemens cans, which are very good. Rifa are also very good.
But about the dullnes you report, I would look that somewhere else, perhaps in the preamp section. I couldn't find an schematic for that amp, to see where to improve.
Old 17th February 2009, 01:27 PM   #24
SQLGuy is offline SQLGuy  United States
Mouser carries Nichicon, including the KG and KZ series. No minimum order and pretty good prices. But, they don't carry the 10000uF 63V in this series. The highest they seem to have available is 6800uF at 63V, and these are non-stocked.
As for the emitter resistors' wattage, at 200W continuous into 4 Ohms (does the Rotel do that?), they'd be dissipating 1.22W each. I think 2W is safe, unless this amp is stable into 2 Ohms and doubles all the way down.
Old 17th February 2009, 06:18 PM   #25
The resistors are metalplate cement resitors, if you google on how they are manufactured youll notice they have nothing to do with wirewounds, thats what mpc stands for. Wirewounds have higher inductance which will cause this amp to oscilate as it uses a triple darlington output and most probably does not even have a output coil. I have repaired some models where a repair shop substituted these resistors for plain wirewounds, and then didnt bother to put the amp on a scope, disasterous. Wirewounds are fine to use here if high quality non inductive brand like mills is used. Use 5 watt resitors.
If the caps are changed to Muse types, I think you going to be dissapointed in the sound. The Muse are not bad but compaired to the slitfoils they dissapoint. For same or better quality youll have to go up to siemens and now made by epcos, sikorels, they cost a little fortune, but maby you can get them somewhere at affordable price.
Old 22nd March 2009, 08:59 PM   #26
Bartt is offline Bartt  Netherlands
Thnx for all the advice! I replaced the emittor resitors for a 5W version MPC-71 except for 2 (could only get 10 of them). I also replaced the trimpots with multi-turn types. The sound is better and more stable in time. The bias doesn't drift that much anymore and left and right channel are more or less the same.
I still have the feeling that something elso is (also) wrong. The Rotel has been repared (under warrenty) twice because of some damage related to my 18' Volt subwoofer I connected to the "speaker remote" terminal (couldn't handle it when I switched it on at medium volume...). Lots of joints have been resoldered and probably some parts have been replaced. What else could be wrong and how can I test it?
Maybe I should check the zobel resitor too. Is that the one near the speaker terminal?
How can I check if the output transistors are okay?
Old 22nd March 2009, 10:19 PM   #27
Hi Barrt, good to see that the bias is more stable, I would however try to get the other 2 resistors replaced as well with same types. Check the zobel resistor and if possible if you could take a photo of the output transistors but in a way so I could see their markings. Im not afraid that there might be a blown one, but as you say that the amp has been repaired before Im wondering if original parts were used. Some repair shops put in fakes, usually the bias transistor is also mounted on the this heatsink and I would like to see how it was done and if the original transistor is still in place.
Old 26th March 2009, 07:37 AM   #28
I tried to make a picture of the output transistors, but it's a bit difficult to get a good shot with everyting on it. Left and right channel are not exactly the same:
3x B817 D 5F3 and 3x D1047 D 5E3
3x B817 D 5F3 and 3x D1047 D 5F1 (!)
Is that bad?
Do you know where can I find the zobel resistor?
Old 26th March 2009, 07:39 AM   #29
hope you can see the picture now ...
Old 26th March 2009, 08:13 AM   #30
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
Bartt,
5F1 is batch designation, I would not worry too much about different numbers.
ROTEL amp sounds dullHide this!Advertise here!
Rotel RCD950 sounds distorted Bartt Digital Source 1 27th March 2009 09:53 AM
Dull mind looking for speaker help justn Multi-Way 8 11th August 2005 06:50 PM
