diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Laney HCM160B's transistor (http://www.diyaudio.com/forums/solid-state/137781-laney-hcm160bs-transistor.html)
zvir 2nd February 2009 11:18 AM
Hi fellas.
Sorry about this kind of question, it's probably basic, but i am a newbie, and just learning.
I got a used bass amplifier. You can see the model name in the title. anyway, i turned it on and cranked the volume way up. When I started playing, the result was not a least bit pleasant. Distortion and crackling noises were ruining the sound. But, when the volume is not way up, the amp sounds OK. So, i opened it up and i saw that a pair of power transistors had been replaced. The originals were Sanken's SAP16P and SAP16N, but inside i found SAP15's. I found some datasheets on the internet which say that SAP15's are weaker than SAP16. So, what i want to know, can this be the sole reason for that bad sound i mentioned? Or is there anything else i should be careful about? I am planing to try and get a pair of SAP16's and change them.
zvir 16th February 2009 11:45 AM
I have some new information. I o'scoped the preamp output, and by the traces, I think it is distorting. I can post screenshots if someone can look at them and tell me anything useful...
kevvywevvywoo 16th February 2009 10:23 PM
Yep put em up, but feed the amp with a 200Hz sine wave will you? Dont just play music through..it'll be confusing on the scope.
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
