How to measure phase margin of an amplifier?
Old 20th January 2010, 01:34 AM   #21
Bob Cordell is offline Bob Cordell  United States
Originally Posted by traderbam View Post
When I talk about delay I mean time delay. I use the term phase shift and sometimes phase lead or phase lag to describe what I assume you mean when you use delay. That is, the apparent phase delay of a simple sinusoid. I notice a number of novice's get easily confused between the concepts of inertial phase shift and time delay and I like to point this out now and again for clarification.
I meant time delay, as in so many nanoseconds. Phase lag that increases linearly with frequency is time delay. Well below a pole, the phase shift vs. frequency of that pole is somewhat linear, so it looks like time delay.
Bob
Old 20th January 2010, 03:08 AM   #22
syn08 is offline syn08  Canada
I don't think you need tons of explanation so here are a few grams.
CL performance is the goal. Seems self-evident to me.
I don't disagree with what you are saying (ok, at least high level), so let me reformulate:
Do you think there's any parameter in a closed loop system that cannot be evaluated by the loop gain analysis?
To me it's a "nay". That's all I'm saying, a loop gain analysis will always provide a correct and complete prediction of the closed loop behaviour.
Old 20th January 2010, 11:20 AM   #23
traderbam is offline traderbam  Europe
traderbam's Avatar
In theory, if you know everything about the OL circuit and you know exactly how you will change it when you make it CL then you should be able to fully predict the CL behaviour.
In practice, it is not possible and so I am recommending relying only on the CL performance.
“Simplicity is the ultimate sophistication.” Leonardo da Vinci
Old 20th January 2010, 11:25 AM   #24
traderbam's Avatar
You seem to be muddling up common English and engineering terminology. And this is my point. The sentence "Phase lag that increases linearly with frequency is time delay." is an engineering no-no. So I recommend not using the word delay in the NFB context when describing phase shift. Because folk really do get confused.
Old 20th January 2010, 11:39 AM   #25
wahab is offline wahab  Algeria
using the open loop transfer function caracteristics,a nyquist plot
allow to define the closed loop stability behaviours of a negative feeddback
circuit..
thus, applying negative feedback doesn t change the intrinsical transfer
function of a system....
Old 20th January 2010, 02:10 PM   #26
OK, I am having trouble understanding your objection. I think you understand what I am trying to say. Let me know how you would state it so I can better understand.
I do like to use terms that are commonly understood, and maybe I am taking too much liberty here. On the other hand, your objection may be based on a philosophical one of yours, in that you philosophically disagree with using the concept of delay in looking at how feedback works.
Let me state one more time, that I am referring to simple delay, as if it were physical delay. If I inserted 50 feet of perfect wire into the loop, it might introduce on the order of 50 ns of delay (what some call flat delay). This is the kind of delay I am talking about. That 50 ns of delay will add 18 degrees of phase lag to the loop at a frequency of 1 MHz. In other words, it will detract from phase margin by 18 degrees if the gain crossover frequency is at 1 MHz. Do you agree with this assertion?
Moreover, I am saying that three or four added poles at some frequency(s) well above 1 MHz will largely approximate the delay described above.
Bob
Old 20th January 2010, 03:24 PM   #27
traderbam's Avatar
Bob,
The handy thing about using maths and science is that one don't have to faff about with philosophical interpretations. One can, instead, say this is X and is not Y and prove it. Provided the rules and terminologies are clear.
A pole is not a time delay (Laplace: e^(-ts)). The roll-off and associated phase shift due to a pole is not caused by a time delay.
You may quantify the phase shift of a sine wave that a pole causes and convert this to time displacement. But this time displacement is nothing to do with a time delay in the system.
Is this clear?
Brian
"A time delay will cause a linearly increasing phase lag with frequency" is how I would restate what I think you are expressing.
Old 20th January 2010, 03:41 PM   #28
Bob,
Is this clear?
Brian
I have no problem with your re-statement that "a time delay will cause a linearly increasing phase lag with frequency".
However, I never suggested that a single pole was the same as a pure time delay. This is where you seem to be missing the boat.
What I said, or meant to say, is that a group of multiple poles can cause a nearly linearly increasing phase lag with frequency (over a limited range of frequencies depending on the tolerance you allow for the approximation) that emulates a time delay with reasonable accuracy. To the feedback loop, this gives the appearance of a constant time delay, well in the vicinity of the gain crossover frequency. If you simulate three poles at 5 MHz, 10 MHz, and 20 MHz, and look at the phase vs. frequency +/- one octave about 1 MHz you will see what I mean.
Once again, I NEVER suggested that a single pole was the same as a time delay.
Bob
Old 20th January 2010, 04:07 PM   #29
traderbam's Avatar
Originally Posted by wahab View Post
since there s some expiremented people by there,
i ve got a question..
what is, by your experiences, the accuracy of
simulators in checking these parameters, phase margin
and gain margin?
is real world largely different from the virtual experiments?...
thanks for the insights,
80% accurate.
This is a great question and probably best answered by Andyc. There is a great thread about simulators somewhere around here.
A real circuit contains many, many more "components" than you tend to see in a typical LT Spice model and the "typical" device model parameters will not be identical to the parts you actually use, so it's a garbage-in, garbage-out thing.
So my opinion is that simulation is hugely useful but it is no substitute for measuring the real circuit.
Old 20th January 2010, 04:11 PM   #30
This is where we disagree. Care to explain why would theory be here different to practice? Again, I'm talking about measurements, not simulations.
How to measure phase margin of an amplifier?Hide this!Advertise here!
Leach150 phase margin problem!!! mclarenpingu Solid State 27 3rd March 2008 08:44 AM
Measuring Phase Margin davidallancole Solid State 4 19th December 2007 06:18 AM
Diff amp input cap for improved phase margin pooge Solid State 47 14th July 2007 09:11 AM
Copyright ©1999-2017 diyAudio
