square wave in = square wave out
Old 14th April 2003, 09:40 AM   #11
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default square waves
I don't think square waves are good to judge the sound reproduction quality of an amp. But there are quite usefull to test the stability margin (which has an influence on the sound quality of course).
The amp should pass a square wave like the 2nd curve of phase-accurate's previous post.
The rise time of the edges determines the 3dB freq response point (3dB = about 1/pie the equivalent freq of the rise/fall time).
There should be not more than 10-15% overshoot (that's my target, YMMV). Then what I normally do is load the amp capacitively (from 10.000pF to 1uF) and keep an eye on the square wave response. For poweramps I use some cable between the amp and the cap load to introduce some inductive impedance, because it really isn't fair to ask the amp to cope with a cap directly at its output jacks.
The same with preamps, I use up to 1000pF to simulate (too) long high-cap interconnects.
If in any of these cases the amp oscillates or is marginally stable the square wave response will show very high overshoot and/or oscillatory bursts.
Jan Didden
Old 14th April 2003, 11:03 AM   #12
jh6you is offline jh6you
Account Disabled
Originally posted by phase_accurate
a squarewave of 200 Hz
It seems to show
- LF gain: good
- LF delay: insufficient
- HF gain: good
- HF delay: excessive
- Damping: high.
Am I correct?
JH
Old 14th April 2003, 11:31 AM   #13
phase_accurate is offline phase_accurate
This has not much to do with gain or delay. Since the topic was mentioned within a speaker thread of Richard as well, I posted the response of a phase accurate two-way speaker system.
The waveshapes are those of a wide fourth-order bandpass. The tilt is caused by the lacking ability to reproduce DC. All waveshapes are damped quite well and the tilt is not to be mistaken as overshoot, though one is led to believe this. The flattened slopes of the rising and falling edges are simply caused by the finite rising and falling speed.
Many amps would be better than this example in terms of HOW MUCH, at least at the lower end (where a very low first order rolloff is easily achieved with SS amps, even DC reproduction, but more difficult with tube amps). But the general SHAPE would be the same, as long as there is no ringing.
But keep in mind most speakers will be worse.....
As Peranders stated, rectangular tests are quite good for determining stability. It is not by accident one of the vavourite test signals for almost any feedback control system !
Charles
Old 14th April 2003, 11:40 AM   #14
Account Disabled
Understood. I was thinking about the amp...
JH
Old 14th April 2003, 11:55 AM   #15
And I am afraid that I wasn't clear enough before......
Charles
Old 14th April 2003, 07:58 PM   #16
Pedja is offline Pedja  Serbia
Default squarewave and...
With speakers, it is a bit different than with amps or digital.
With speakers there is a problem of aligning two or more sections in parts which in sum give that what was the starting point. It is not a hard task in the term of the amplitude response, but the things become worst when phase come in story. As sad in another thread, assuming linear amplitude response, impulse (transient) response is directly related to the phase response.
Charles, can you give us some more info about the system whose graphs you posted? Thanks in advance.
Pedja
Old 14th April 2003, 08:16 PM   #17
Pjotr is offline Pjotr
Pjotr's Avatar
Square waves are a good test signal. Butů.
You need to band-limit the input signal between 50 kHz and 100 kHz with at least a 1st order filter. Otherwise if the slew rate of the input signal is too high you will drive the amp partly into limiting (saturation) somewhere. Most time the input stage.
Also a good test signal is a 80% 50 Hz sine with a 20% 1 kHz square wave added. It shows dynamic instability if apparent.
Old 14th April 2003, 10:26 PM   #18
PMA is offline PMA  Europe
PMA's Avatar
Square wave is a very useful signal to test the amplifier. You can calculate both amplitude and phase characteristics from step response or impulse response by means of Fourier transform, I do not want to get into more details.
High frequency limit (-3dB) can be calculated from rise time tr (10%-90%) as fh = 0.35/tr. It imeans that for tr = 1us fh = 350 kHz. From long time duration of square wave (low repetition frequency) one can see low frequency limit of the amp, it corresponds to exponential decay of square wave top line. Square wave is excellent for testing of stability of the amp together with diffrent kinds of load (capacitive etc.). But you have to use several different repetition frequencies of square wave, say 100Hz, 1kHz and 10kHz.
Old 15th April 2003, 07:08 AM   #19
Pedja
The examples shown are from a simulation of a two-way active system using an MSW (Manger Schallwandler).
It was done with a subtractive crossover and equalisation. The equalisation is necessary because the MSW is not that well behaved at it's lower end. More details and discussions can be found within the Manger thread.
I will try another principle for the MSW in the future and the Veroboard prototype of this crossover will find it's final destination in a phase_accurate box with a cheap fullrange (Monacor SPH68X).
Charles
Old 15th April 2003, 11:45 AM   #20
tubetvr is offline tubetvr
I dont understand this one, any competently modern designed amplifier has either a low pass filter included on the input in order to avoid this phenomena or is otherwise designed so that no saturation can occur.
BTW there is a misunderstanding that tube amps can not be good when reproducing squarewaves, even many transformer coupled amplifiers can be give quite respectful results and OTL amps can compete easily with any transistor amp. My own OTL amp have a rise time of ~ 1 us and no overshoot or ringing with capacitive loads up to 3.3uF.
Using square waves is usually a good method of testing amplifiers for stability and frequency response and is easy to use.
Regards Hans
square wave in = square wave outHide this!Advertise here!
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
Square wave Prune Everything Else 11 28th June 2004 06:17 AM
Microphone turns triangle wave into square wave? Circlotron Analogue Source 18 25th January 2003 06:44 AM
Copyright ©1999-2017 diyAudio
