#21 |
Emitter resistors are necessary in the real world as they help in current sharing between paralleled transistors - remember real parts are not perfectly equal in their parameters (especially beta or VGS)
Another point is that simulation regularly predicts unrealistic results. That's due to insufficient models and often also due to incorrect simulation. Just simulate a known amp (where you have all specs and plots) and compare. You will be surprised. In any case, at these low levels of THD also construction details as pcb-layout, wiring, position of the toroid and more become decisive wether you reach your goal or not. Do not keep your eye so close to the simulator, build and measure the beast. Have fun, Hannes PS: if you want real fun, measure THD while moving the wiring in the amp.
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#22 | |
Fotios, I never thanked you properly for your help on the transformers. Thanks, Fotios.
- keantoken
Contribute to the DIYAudio WIKI! http://www.diyaudio.com/forums/every...p-sign-up.html LTSpice wiki with special attention to new users' troubles |
#23 |
Is there something wrong with my MJE340/350s?
There isn't a metal pad on the back. Just plastic. - keantoken
#24 | |
Most TO-126 are like this. In my opinion, a benefit - no isolation washer needed, just grease it up an' bolt it on. |
#25 |
Banned
Hannes,
the quality of your contribution has unexpectedly risen lately. Have you maybe taken an evening class? |
#26 | |
on the backs of the devices, but the new MJE/KSA to-126's are all plastic. Once I found this out I realized you could mount them "backwards" for PCB layouts,etc . No mica required either .OS |
#27 |
I am struggling with this Single End MOSFET Class A.
It is kinda ZEN but uses one current source at 1 Ampere. Output devices are N-Channel. Only four transistors: 2 x 2N5401 and 2 x Exicon ECF20N20 Think two Exicon ECF10N20 will work just as well. At 18 VDC, 1 Ampere = 18 Watt, it can produce 2, maybe 2.5 Watt RMS with acceptable dist. Mainly 2nd and 3rd harmonics. The higher orders will fall off nicely. It is not to make this amplifier optimal. But it is a nice project and fairly low idle powers. Lineup
lineup |
#28 |
Hi Lumba,
not that I'm aware of Especially my last post was plain general info that everybody also finds with a little search here on the forum. But I think you just refer to my putting down of SPICE; I think you maybe misunderstand me here. SPICE is a perfectly nice tool for evaluating amps, but it has it's limits. If you seriously go for anything less than 0.05% THD I would not trust SPICE. The models are - in my experience - much too limited in quality.* Of course one can improve them (andy_c did that), but everybody who is able to do that also knows the above. Have fun, Hannes *real pros excluded.
#29 |
Banned
Hannes,
answering late a previous question, please check this book: Hartmann, William M. Signals, sound and sensation. |
#30 |
Hi Lumba,
thanks for the reference - I'm lucky our library has it. Let's have a look. Have fun, Hannes
| TAS5630 D-Class build | berni8k | Class D | 82 | 3rd April 2012 08:40 AM |
| Help me Build a Class D | alijoorabchi | Class D | 6 | 25th November 2006 03:19 PM |
| i want to build an 400WRMS class d amp | avner31 | Car Audio | 3 | 21st July 2006 03:57 PM |
| Page generated in 2.76800 seconds (4.90% PHP - 95.10% MySQL) with 11 queries |
