a couple of questions on diamond buffer
Old 26th January 2009, 07:44 AM   #11
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
Stefanoo,
do I need TO220 devices and high bias, or i can just Bias as much power as the TO92 can take (wich is about 300mW)?
According to the data sheet, 2SC2240/2SA970 can take 300mW all right (without telling how long, in audio most max ratings are irrelevant anyway), but I would not like to listen to the sound they produce under such condition.
Power dissipation is probably the limiting factor even with 2SC5171/2SA1930, at 25mA being 750 mW.
Old 26th January 2009, 11:59 AM   #12
lineup is offline lineup  Sweden
lineup's Avatar
This is one of the few issues with 2SC2240/2SA970:
.. Can not take very much power!
I have seen figures of 200mW, max.
Less than normal TO-92, like BC550C/BC560C ~500mW
Otherwise, 2SC2240/2SA970 can work att very high voltages .. with matching reduced, low current, of course.
120 Volt C-E !!!, where BC550C/560C are only 45 Volt ..
lineup
Old 26th January 2009, 12:31 PM   #13
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
Hi guys,
i have followed the Lumba's suggestion and increased the output bias to 69mA.
Outptut devices are still running pretty cool, no need for heatsink.
Since i like the sound of the IRFs 610/9610 parts, i am going to use them on the output stage.
The problem is: switching from the low power BC to the IRF gives rise to overshoots.
I don't know, i will try to play around this.
I think that cascoding the 2 BJTs might help this, or i will see if i can do something else.
do you guys have any suggestion?
The compensation would be my LAST resource!
Stefano
Old 26th January 2009, 01:26 PM   #14
Banned
Stefanoo,
this configuration would significantly linearize your output stage.
Old 26th January 2009, 05:47 PM   #15
homemodder is offline homemodder  Portugal
Try this one, not sure what you driving, but this one can drive 1K loads with lower than -120db, mainly second. Best performance is obtained by using very high gain bjts but that have very low cob. Can suggest some but I dont know if youll be able to get them. To adjust output offset simply tweak the output resistors, no input offset. Tweak the currents depending on the transistors used, sounds excellent. What comes in is what comes out, wire with gain.
Old 26th January 2009, 07:10 PM   #16
Stefanoo's Avatar
sorry, but it doesn't let me zoom the picture you have atached.
May you do it again? I can't see it.
thanks.
P.S. just for curiosity, what are the transistor's type you were referring to?
Stefano
Old 26th January 2009, 11:14 PM   #17
I try again, this time as bitmap. I use in general 2sc3495 and complementary, ksac1381 and compl. high gain group also works ok.
a couple of questions on diamond bufferHide this!Advertise here!
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 02:46 PM
diamond buffer for car project djronbxs Solid State 0 17th November 2007 02:06 PM
Diamond buffer in PIMETA slowpogo Chip Amps 3 19th April 2007 06:58 AM
Diamond buffer peranders Solid State 45 16th November 2003 12:00 AM
