Old 24th January 2009, 08:10 AM   #1
Default mains frequency//secondary current
Here in Australia the mains power is around 240 volts at 50 c/s.
I picked up some secondhand PS transformers that were salvaged from equipment made in the US of A and designed for 60c/s. They have multi-tapped primaries (115v,120v and 125vs) and secondaries of 36 volts @ 3 amps. Now they seem ideal for my purposes and I hope to run the primaries in series and use the secondaries to power some "double mono" power amps. But there is a question about the current that is now available in their adopted country. I have been getting two opposing pieces of advice.
The first opinion says that as they were designed for 60c/s I will need to DERATE the secondary current 20% if they are run on Aussie mains of 50c/s.
The second opinion states the opposite and suggests I now have access to 20% MORE current.
Both sets of advice are coming from well qualified people. Anyone come up with a definitive answer please?
Thanks, Jonathan
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse.
Old 24th January 2009, 10:05 AM   #2
Pleeeeeese. Someone must know.
Jonathan
Old 24th January 2009, 10:42 AM   #3
AndrewT is online now AndrewT  Scotland
you will certainly not get more current (VA) by going down from 60Hz to 50Hz.
If the transformer is designed to only run on 60Hz then you will have to de-rate it for 50Hz use. But you are never likely to run the transformer at near maximum rating after start up.
One clue to whether it's suitable for 50Hz use is to check running temperature when the output is open circuit.
If it seems to get too hot then maybe it really is a 60Hz transformer.
I think that adding primary windings will help reduce that heat, but I suspect you will not need it.
Can you safely measure the no load primary current? I guess it should be <=10mA. If it's a lot less then 50Hz is OK.
regards Andrew T.
Old 24th January 2009, 11:04 AM   #4
Steerpike's Avatar
The seriesed primaries will be good for 2x125=250V at 60Hz, so 240V input is already giving a bit of leeway.
One other thing to note: if you are running the primaries in series, you should ensure both transformers are loaded equally - either by wiring the secondaries in series too, or in parallel.
Old 24th January 2009, 11:53 AM   #5
MondyT is offline MondyT  United Kingdom
Hi Jonathan
If the transformer is designed for standard 60Hz mains input then you are going to need to reduce the input voltage by a factor of 50/60=0.833 at 50Hz or you will more than likely saturate the core. If you have a 250v tap for 60Hz, then the maximum 50Hz voltage you can apply is 208v. Manufacturers do not normally give much leeway except say a 10% over voltage capability as copper costs money!
The loading on the secondary does not have any bearing on this as the magnetising current for most part remains the same despite loading and therefore the flux density in the core remains the pretty much same from no load to full load
Cheers
Ray
Old 24th January 2009, 09:39 PM   #6
Banned
Ray,
nice explanation.
Old 25th January 2009, 04:15 AM   #7
Thanks guys. Appreciated. Jonathan
Low Frequency Mains Noise ruffrecords Tubes / Valves 6 31st October 2008 07:26 PM
Mains frequency variation Circlotron Everything Else 11 3rd March 2008 10:49 AM
Why is mains frequency so low? Nixie Parts 3 29th November 2006 11:13 AM
Change in frequency mains Raka Analog Line Level 49 17th January 2006 04:59 PM
Mains frequency stability Prune Parts 10 26th November 2004 05:09 PM
Page generated in 0.24580 seconds (29.29% PHP - 70.71% MySQL) with 10 queries
