HIRAGA higher power
HIRAGA higher power
Old 24th January 2009, 06:03 AM   #1
Williams Audio is offline Williams Audio  Jamaica
Default HIRAGA higher power
The ‘hiraga classe A’ amps are relatively low power
There is some one that increased the power higher then ‘ le monstre’ 30 watts?
I was thinking of increasing the VCC to +/-50v and the voltage gain, keep the current bias around 1.5 amps getting 100 watts; the big question if it works properly.
I ran some simulations but I am not pleased with the results.
If some one can help and advise I will be grateful.
Best regards
Williams
williams audio
Old 24th January 2009, 10:05 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
You can search forum for Monstre
I do not remember if we discussed higher power here:
Hiraga "le monstre"
http://www.diyaudio.com/forums/showt...?threadid=5462
But sure it could be possible.
On the other hand, is often said that
One 10 Watt Class A .... can match 50-100 class ab amplifiers ... in sound quality
10 Watts RMS means +10 dB
If your speakers are SPL 90 dB/1 Watt, you will get like 100 dB level
lineup
Old 24th January 2009, 10:10 AM   #3
lineup's Avatar
You have hiraga alternative amplifier with 20 Watt:
Hiraga 20W Class A
http://www.diyaudio.com/forums/showt...p?threadid=193
Daniel has made some great, great amplifier there.
See his latest images and posts.
For example here is one picture of his work:
http://www.diyaudio.com/forums/attac...amp=1231062965
Lineup
lineup
Old 27th January 2009, 10:05 PM   #4
danieljw is offline danieljw  Australia
danieljw's Avatar
Send a message via MSN to danieljw
Hi Lineup,
Thanks for the nice comments i am flattered!!!
that version i made of the 20W class A amp recently measured well.
I have actually written a little article on it for another site when it is finished i will post it it has pictures and measurements and the exact cricuit etc etc...
any how the amp ended up making about 56W rms,
if you used a larger output stage for example sanken 230 or 250W devices - (but still a single pair) and a couple of resistor/transistor changes you could get more power, however the heat would be quite difficult to get rid of !!!!
-Dan
Old 30th January 2009, 11:15 AM   #5
Hi daniel,
You built nice things. I built the Douglas Self class A amp and increased the vcc supply so, could get ~45w @ 8 ohms, but I want to build a simplier pwr amp in class A.
My spk are Acoustat 2+1 so I need some thing around 100w.
From my sim, Hiraga amp, when is switching to class AB from class A in order to deliver a higher output power is very distorted and needs to be bias at very high current in order to keep it clean, so I am wondering if can increase the output power of Hiraga amp with out distortions or degrade performance!
How did you rise up the output power?
best regards
Williams
williams audio
Old 30th January 2009, 10:04 PM   #6
danieljw's Avatar
Hello Williams,
I increased the rail voltage and also the bias, you need to change a few parts also to do this,
but i think it is worth the effort
-Dan
Old 31st January 2009, 09:08 AM   #7
Hi Daniel,
looks that can be done, can you mail some more details on the
schematics and final power
best regards,
Williams
williams audio
Old 31st January 2009, 10:16 AM   #8
danieljw's Avatar
Hi Williams.
attached is the orignal
Old 31st January 2009, 10:18 AM   #9
danieljw's Avatar
here is the version i am using at the moment
Old 31st January 2009, 10:52 AM   #10
Hi Daniel,
thanks alot i am testing the new scematics, next week i am starting the project. very nice you answered that fast.
have a nice weekend,
best regards,
Williams
williams audio
HIRAGA higher powerHide this!Advertise here!
Higher power A75. dinu Pass Labs 76 15th January 2008 07:23 PM
Paralleling VAS devices for higher power rtarbell Solid State 6 19th November 2005 08:37 PM
power output higher than power supply...How? loonatron Analogue Source 9 24th March 2005 08:04 PM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 05:28 PM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 05:01 AM
Copyright ©1999-2017 diyAudio
