The ‘hiraga classe A’ amps are relatively low power
There is some one that increased the power higher then ‘ le monstre’ 30 watts?
I was thinking of increasing the VCC to +/-50v and the voltage gain, keep the current bias around 1.5 amps getting 100 watts; the big question if it works properly.
I ran some simulations but I am not pleased with the results.
If some one can help and advise I will be grateful.
Best regards
Williams
Best regards
Williams
You can search forum for Monstre
I do not remember if we discussed higher power here:
Hiraga "le monstre"
http://www.diyaudio.com/forums/showthread.php?threadid=5462
But sure it could be possible.
On the other hand, is often said that
One 10 Watt Class A .... can match 50-100 class ab amplifiers ... in sound quality
10 Watts RMS means +10 dB
If your speakers are SPL 90 dB/1 Watt, you will get like 100 dB level
Hiraga "le monstre"
You have hiraga alternative amplifier with 20 Watt:
Hiraga 20W Class A
http://www.diyaudio.com/forums/showthread.php?threadid=193
Daniel has made some great, great amplifier there.
See his latest images and posts.
For example here is one picture of his work:
http://www.diyaudio.com/forums/attachment.php?postid=1702881&stamp=1231062965
Lineup
Hiraga 20W Class A
Lineup
Hi Lineup,
Thanks for the nice comments i am flattered!!!
that version i made of the 20W class A amp recently measured well.
I have actually written a little article on it for another site when it is finished i will post it it has pictures and measurements and the exact cricuit etc etc...
any how the amp ended up making about 56W rms,
if you used a larger output stage for example sanken 230 or 250W devices - (but still a single pair) and a couple of resistor/transistor changes you could get more power, however the heat would be quite difficult to get rid of !!!!
-Dan
-Dan
Hi daniel,
You built nice things. I built the Douglas Self class A amp and increased the vcc supply so, could get ~45w @ 8 ohms, but I want to build a simplier pwr amp in class A.
My spk are Acoustat 2+1 so I need some thing around 100w.
From my sim, Hiraga amp, when is switching to class AB from class A in order to deliver a higher output power is very distorted and needs to be bias at very high current in order to keep it clean, so I am wondering if can increase the output power of Hiraga amp with out distortions or degrade performance!
How did you rise up the output power?
best regards
Williams
best regards
Williams
- HIRAGA higher power
