Old 25th January 2009, 12:51 PM   #11
Michael Chua's Avatar
Hi OS
It won't work with a cap as shown. It should be a resistor instead. Something like 47K.
Mike
AmpsLab.com
Old 25th January 2009, 01:04 PM   #12
ungie is online now ungie  Canada
Originally posted by ostripper
That is strange.., AC coupled offset adjust???
Does that use the ESR of the cap to affect the offset?
OS
Originally posted by Michael Chua
Hi OS
Mike
I was thinking the same thing, but surely the same error could not have been made on more than one Perreaux schematic?
See this post for an identical DC offset arrangement:
http://www.diyaudio.com/forums/showt...876#post895876
I should also note that I find it strange that both channels are showing a nearly identical high DC offset.
I will go through and check/replace all of the small electrolytics first to see if leakage is the issue.
Old 25th January 2009, 01:08 PM   #13
Originally posted by jacco vermeulen
The PMF models were biased in Class A to 10% of the nominal output level : 50W for the 5550, aka 2.5A, is 200mA per output device.
The current is measured at the rails.
jacco, you don't happen to have any service documentation for this or any other Perreaux amps of this vintage, do you?
I read in another thread about setting bias on these amps that the prodcedure is a little more involved than normal for setting DC offset and bias. Something about using an ammeter in place of the rail fuses, etc.
Thanks!
Old 25th January 2009, 01:45 PM   #14
If there are no emitter resistors to measure the output stage bias, then solder 10r0 across the fuse holders in the supply rails. Tiny 1/8W or 1/4W resistors are ideal here. Leave them in permanently. They will blow with the fuses on abuse/overload/failure.
Remove the fuses and measure the volts drop across the 10r0.
This gives the quiescent current of the amplifier. Output bias current < amplifier quiescent current.
If the quiescent current >100mA then use 4r7 or 5r1 resistors.
Old 25th January 2009, 02:49 PM   #15
That's a strange one. I don't see how having a cap there helps to adjust DC offset. Maybe some experts can enlighten us on this.
The PMF models were biased in Class A to 10% of the nominal output level : 50W for the 5550, aka 2.5A, is 200mA per output device. The current is measured at the rails.
If you decide not to use an ammeter, try to get hold of a 0.1 ohm Current Shunt. You would want as low a voltage drop as possible across the shunt resistor.
Mike
AmpsLab.com
Old 25th January 2009, 03:43 PM   #16
sakis is offline sakis  Greece
sakis's Avatar
Default help please cause here i miss something
OK !!!! more or less everybody knows that my theory is not really enough .... but looking at this schematic there is a lot of things that i dont really understand ....
A)what about output resistors ..... amplifier i worked with (Legend4) didnt include any and all forum members were screaming about this ..... similar to this is the discusion about the JOY 200 amplifier ( an sziklai with 4 out transitors with out any out resistors ) so what's the catch here ????
B) since legend 4 was didnt include ccs in the vas or ltp stages was called a "POOR " design and not really stable as far as i can see from this schematic at least in the ltp stage there is no ccs here also . ......
C) can somebody tell me if this design is stable ???? then again how much power ???? and what is the rail voltage ...????
D) is this amplifier takes as a very strickt fact that outputs must be very well matched ????? or wtf is going on here ?????
answers please i am very confused now .....
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 25th January 2009, 04:09 PM   #17
ostripper's Avatar
It is balanced , I have built/ simmed this topology and if properly laid out and compensated it CAN be very stable.. seems to run off
of +- 118 V rails and 113v for VAS/LPT. CCS would
be better for PSRR.
Outputs would have be matched.. A wire is very bad at
current sharing.. this is the same as the HH1200MX power amp
but a little more crude. (see attachment)
OS
Old 25th January 2009, 04:28 PM   #18
Stormrider's Avatar
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
+/-90Vdc on two pairs of TO3's ?!!!
AJ
Old 25th January 2009, 04:55 PM   #19
sakis's Avatar
Default thanks OS
but your answers dont look really enough ......
what i mean is ....How come an amp like that runing at so much high rails doesnt requier CCS and out resistors ????
the circuit i was working with had only 4 mosfets and rails at max of 60 volts and i never managed to make it work propelry ( forum members also tryied to advice me but always we end up that deisgn is poor since dont have resistors vas and ltp without CCS )
what do you think that is the expected output of this amp ???? my calulation say that 500W is very possible given as a fact a very good psu ...am i correct ????
Old 25th January 2009, 05:01 PM   #20
sakis's Avatar
Default ITS NOT !!!!!
you have to look at the schematic again ..... its 12 outs totally but only 4 shown on the schematic ......
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
