wattage question
2 Attachment(s)
just curious after reading this thread...
http://www.diyaudio.com/forums/showthread/t-112471.html I am unclear of the how many watts this amp puts out. I am calculating about 60watts. I have been known to be bad at this amp calculation stuff, so I figured I'd ask. |
40 Volt - 5 V (mosfet gs) = 35 Volt total
35/2 = +- 17.5 Vpeak 17.5/1.414 = 12.4 Volt rms max ouput Max 8 Ohm: 12.4 x 12.4 / 8 = 19.2 Watt RMS Max 4 Ohm: 12.4 x 12.4 / 4 = 38.4 Watt RMS Something like that for a 40 Volt DC supply. The output, between MOSFETS, should be ajusted to something like 15 - 17 Volt. Either for symmetrical clipping or minimum distortion at higher levels. |
wow, I was way off! :xeye:
glad I asked. |
The irf540 being a 88w device in a to220 case may not be
up to the task of handeling all that heat! |
lineup excuse my ignorance but
This calculation is made in each MOSFET = 2.5 v total of the two 5v. you would use bipolar transistor 0.6 +0.6 v I correct? |
Even without output losses this voltage gives a max power of 24W at 8 ohm. Switching to bipolar won't buy you much additional power.
2 Attachment(s)
Hello Beto.
See attachment. Actually I forgot that 2V is used by lower MOS. Like 2 A ClassA bias. While like 5V, VGS, is lost in upper. So totally we have 40 -2 -5 = 33 Volt (at best for output swing) Same as +- 16.5 swing. At idle, output voltage is at 18.5 VDC. Output can not go lower than 2V .. because of MOS Current source. Output can not go higher than 35V, because there Gate of MOSFET is at 40 VDC (supply max). Result output +-16.5Vpeak = 11.66Vrms Power 8 ohm : 11.66x11.66 /8 = 17 Wrms Power 4 ohm : 11.66x11.66 /4 = 34 Wrms These are teoretical max. In reality will be some losses and less power out. ==================== This amplifier maybr benefits from BOOTSTRAP. Split up R3 (6k8) into two 3k3. Bootstrap with 47-100uF, from output to BETWEEN 3k3 resistor. Regards :) |
Ok thank you for explanation lineup. :D
wattage concuest may be ????
in my company i own about a 50 pro amps for PA rentals ....the smalest is like 350w per channel .......
still all day i listen to music coming from a nicelly made P3 from esp .....something like 40+40 watts .... can't change that .... now i am an edict ..... |
It seems to me that the bias is all wrong:
BJT base voltage is around 5V BJT DC current is around 5mA => BJT collector voltage 10V Now, how can you expect a decent voltage swing? Or am I missing something? I would decrease R3 to, say, 3k3 or something... |
| All times are GMT. The time now is 01:38 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
