wattage question
wattage question
Old 22nd January 2009, 12:32 PM   #11
lineup is offline lineup  Sweden
lineup's Avatar
Yes, you are probably right.
Of course we should adjust the output voltage point.
This can be done by increasing R6 (27k). Could be replaced, temporary, with one 50-100 kohm trimpot.
My earlier post estimation of a good DC operation point for output,
would indicate something like 16-18.5 Volt.
A bit lower than 1/2 of supply voltage.
The Voltage Gain, Gv, is defined by R3/R5.
Which gives approximate ( 6k8/330 ) Gv = 20.
A bit lower gain than 20 can be expected..
lineup
Old 22nd January 2009, 04:18 PM   #12
R.I.P.
this is a single ended amplifier with a constant current load.
If the bias (and CCS) is set to 2A then the maximum current swing from the amplifier is 2Apk.
Don't even think about using less than 8ohms speakers.
Even these will require much more than 2Apk on short term transients.
regards Andrew T.
Old 22nd January 2009, 05:10 PM   #13
lineup's Avatar
True!
And as MOSFET will get hot (80 Watt idle)
it is questionable if IRF540 (TO-220) can make 40 Watt each.
IRF640 or even IRFP240 may be required ...?
lineup
Old 23rd January 2009, 08:34 AM   #14
R.I.P.
SOAR of the 540 is not a problem.
You can run Tc<=100degC leaving an effective dissipation of 40W from the devices.
The problem is peak current on transients. This amp can only deliver 2A and will current clip.
A heatsink of about 0.6C/W to 0.7C/W for 40V & 2A will work at these very high temperatures. The amp can deliver about 15W to 16W into 8r0 but it cannot deliver into a reactive 8ohms.
However, it could make an excellent 9W into 16ohm amplifier.
or
reduce the voltage to 30V and increase the bias to 3.5A on a 0.3C/W sink for 8W into 8ohms speakers
I would be tempted to run with a pair of isolated heatsinks, with each FET direct coupled to it's sink.
regards Andrew T.
Old 23rd January 2009, 11:06 AM   #15
lineup's Avatar
Okay, so the IRF540 may do it. This is good.
IRF540N variant is even better for higher heat.
When I design Class A, I use some 'normal worst case' numbers to calculate for current.
If make class A for 8 Ohm .. I use Bias Current for 5 Ohm (+ 10% extra)
for nominal output power level.
Same way, for 4 Ohms speakers, it is better to use like 2.5 - 3 Ohm value
for the calculations.
Yes, using like 30 VDC and 2.5-3.0 Ampere may be a first best try.
lineup
wattage questionHide this!Advertise here!
Resistor wattage question DeadSpeaker Solid State 12 17th March 2008 09:41 PM
Does preamp wattage effect power amps wattage? JonnySwitchblade Solid State 7 4th July 2007 03:18 AM
Resistor/LPAD wattage question DerrickM Multi-Way 13 15th April 2007 09:10 AM
power amp into 412 Wattage question twizza Solid State 11 16th June 2005 10:40 AM
Dumb Question about Wattage Calc e.lectronick Pass Labs 2 14th November 2003 07:49 PM
