Modifications to the Adcom 535 or 555?
Old 13th April 2003, 02:54 AM   #1
stokessd is offline stokessd  United States
stokessd's Avatar
Default Modifications to the Adcom 535 or 555?
I was wondering if there is any collective knowledge on the board as to some good modifications to the first generation Adcom GFA-535 or GFA-555? I've got the schematics for the 555 (the 535 appears to be very similar but scaled down). The designs look to be quite solid, but sound a bit harsh in the upper octaves.
They strike me a good candidates for modification as there are a ton of them out there and you can pick them up quite cheaply. In the case of the 555, there more room in that amp chassis than in my Miata trunk...
So is there anything good out there for these fairly good performers?
Sheldon
Old 13th April 2003, 06:45 AM   #2
thylantyr is offline thylantyr  United States
Try this thread for tips.....
http://www.diyaudio.com/forums/showt...ighlight=adcom
Old 13th April 2003, 07:37 AM   #3
stokessd's Avatar
Thanks for the pointer to that adcom thread. I've been through that several times. I downloaded the schematic and the power supply regulator circuit as well.
that thread doesn't really address mods to these amps and whether it's effective, worth it, etc...
That caught my eye was: "Personally, I would score a few of these and run them till they die and then update them. If you wait long enough, an update will be issued." -- Nelson Pass
Sheldon
Old 13th April 2003, 12:57 PM   #4
GaryB is offline GaryB  United States
Default 535 mod
Sheldon,
Quite a few years back I tweaked an Adcom 535 for my brother-in-law and found it to be a rather nice amp.
I don't have the amp here, so this is just from memory. The biggest improvement came from playing with the front end. It uses a bipolar differential pair at the input. Unlike the 555 schematic, the pair is simply loaded with a resistor, not a current source. I added bootstrap cascode transistors to the two bipolar input transistors and increased the operating point of the transistors to slightly higher current. This seemed to nicely open up the high end and soundstage with no downside. Of course, you need to change the associated resistors to compensate for the different currents.
I think I also applied standard tweaks like adding a bit more power supply capacitance locally distributed close to the output transistors and that helped out the low end a bit.
---Gary
Old 13th April 2003, 02:07 PM   #5
Default Bootstrap Cascode
Here's an input circuit from E. Borbely showing the type of bootstrap cascode that I used in the Adcom. Of course, the Adcom uses bipolar inputs, not jfets and the circuit would only need the top half. Still, for those not familiar with bootstrap cascoding, it illustrates the principle.
---Gary
Old 13th April 2003, 04:53 PM   #6
Jarno is offline Jarno
Default Adcom mods
Hello Sheldon,
I own an Adcom GFA535 and, while it is a nice enough amp, I couldn't get my 6mm2 speakercable in the terminals so I replaced those. And while I was at it, I also removed the complete "speaker A-B" circuitry. Can't tell if it sounds very much different though, electronics upgrade seems more worthwhile sonically.
Greetings,
Jarno.
BTW. I like your website, I'm into photography as well.
Oemptempa petoempetapap
Old 13th April 2003, 05:32 PM   #7
On Hiatus
SY's Avatar
If you run into an extra 555, let me know, I'd love to have another one or two.
Before the major butchery that is my current version of the (original) 555, I got rid of the electrolytics in the feedback and input paths and put in a servo. The servo was a non-inverting integrator, set to about a 3 or 4 Hz corner frequency, with an extra passive RC pole (fc of about 50 Hz) at the output. The extra pole was put in just in case there were any extraneous noises coming out of the servo.
It worked quite well for 15 years, the only downside being some turn-off thumps. I'm sure that playing with the charge/discharge rate of the servo's power supply would have dethumped the circuit, but I was always too lazy to fix it.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 15th April 2003, 02:16 AM   #8
stokessd's Avatar
The first thing I did to my 555 was to replace the input jacks. The dreaded previous owner, totally screwed them up. Other than that, it's bone stock.
The 535 had it's output jacks replaced before I ever powered it up (I used superior electric gold plated 5 way posts on an FR4 circuit board). I also replaced the input jacks, and bypassed the bias electrolytic cap with a film, and replaced the bias pots with 10 turn ones. All the power supply caps are already bypassed and the feedback electrolytic cap is also bypassed.
I played with the bias on the outputs to try to find the minimum distortion point, but it seems that the bias drifts with time too much if I crank up the bias (not enough temperature feedback to keep the higher bias stable).
Gary-
Were you able to implement the cascode circuit on the original PCB?!
Sheldon
Old 15th April 2003, 11:56 AM   #9
Well I did put all of this on the original circuit board but I used a lot of free space wiring. Its not as bad as you might think, although it definitely looks as if someone modified it.
Basically, I just unsoldered the original bipolar collector leads and soldered these to the emitters of the new cascode transistors. Collectors of the cascode transistor goes back in the circuit board lead. The two base leads and wired together in free space, the bootstrap zener goes from this lead to the diff pair emitter resistor/current source (don't recall which). Add another resistor from the cascode transistor base up to the postive power supply and you're done. Just don't forget to account for the extra current flowing into the diff pair resistor/current source. I think I used LM336Z2.5, which are low noise 2.5v zeners biased at about 1ma.
---Gary
Old 10th April 2004, 07:22 PM   #10
eastern.enigma is offline eastern.enigma  Canada
Default The No Brainer 535 II 'Tweak'
Hello,
I'm a 535 II owner who's relatively new to audio and DIY. I'm building an entry- level system based on Arthur Salvatore's guidance at http://www.high-endaudio.com/rec.html (highly recommended). Anyhow, here's something I picked up somewhere on the net (audioreview?): replace the fuses with ceramic fuses for about $10 or less (Radioshack).
I tried it and was shocked with the result; it has to be the best per dollar improvement possible. I've e-mailed Nelson Pass on the subject, and his response was:
"I don't know offhand, but there is resistance and signal modulation in the fuses, and the bigger the value of the fuse, the less of that you'll see. Another possibility is that one or more of the fuse connectors was oxidized or dirty, which really degrades the connection, in which case new fuses might have cured that.
"Probably 1 of the fuses is the AC line fuse, which I would not fool with further, but the remaining are in series with the supply rails of each channel. You might consider bypassing those with wire"
My grateful thanks to Mr. Pass for his response. I've replaced the AC line fuse with an equivilent 5 amp ceramic, and the four others (4 amp) went to 15 Amps. How can you go wrong for a $10 tweak?
Modifications to the Adcom 535 or 555?Hide this!Advertise here!
NHT 3.3 Modifications SY Multi-Way 22 22nd June 2008 06:12 AM
DAC-in-the-Box modifications. Again. Aleksunder Digital Source 1 19th July 2007 04:10 AM
DAC modifications elaar Parts 5 29th May 2006 02:11 PM
Adcom GFA-585 went bad - calling Adcom experts hangguy Solid State 14 24th December 2004 09:09 PM
Zen V4 modifications pro Pass Labs 2 31st August 2004 06:19 PM
