Burnt & Destryed my virtual resistor!
Old 19th January 2009, 01:39 AM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Exclamation Burnt & Destryed my virtual resistor!
See attchment.
R1 is one 'rated resistor'. Rated 0.25 Watt. Which can be changed in setting.
R2 is normal resistor. No power rating.
Both are 100 Ohm and at 10 Volt will flow 100 mA (10V/100ohm) in each.
So power in each resistor will be 10V x 0.1A = 1 Watt
What happens in MultiSim spice simulator is.
1. first Ampmeter will show 200 mA
2. after a short while, R1 will burn and be destroyed
with a visually broken resistor body
3. the Ampmeter will show 100 mA, until Turn OFF
This feature can tell where you need to put in a resistor with higher power rating.
If you use rated variants of components in library.
lineup
Old 20th January 2009, 04:42 AM   #2
lineup's Avatar
Ok, no problems!
I have fixed my burnt virtual resistor.
lineup
Burnt & Destryed my virtual resistor!Hide this!Advertise here!
Help! tube amp burnt? flatsound Tubes / Valves 9 26th June 2009 03:41 AM
IRFP064 gets burnt xyz9915 Power Supplies 30 5th February 2009 03:57 AM
Need Help - Burnt Sanken p.heimpold Solid State 16 30th May 2007 06:05 PM
Sub burnt bad. Garbage? Miedosoracing Subwoofers 4 27th April 2006 02:59 PM
burnt transformer A'af Digital Source 1 21st May 2005 12:23 AM
Copyright ©1999-2017 diyAudio
