How to remove knicks on Krell Heatsinks/chassis
Old 16th January 2009, 11:15 PM   #1
john65b is offline john65b  United States
john65b's Avatar
Default How to remove knicks on Krell Heatsinks/chassis
Just aquired a nice Krell KSA300 Chassis and it has quite a bit of scratches and knicks in the (purplish) anodised heatsinks, top/bottom and faceplates....
Anyone know how to clearn them up? Sand/buff them out?
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 16th January 2009, 11:21 PM   #2
hifimaker is offline hifimaker  United States
hifimaker's Avatar
The only way to fill a nick in aluminum that I'm aware of is to weld a small bead to the affected area and then grind and polish it smooth. The anodizing must be removed for weld to adhere. The heat sinks were originally black and turn purple over time caused by high heat. One option is to polish the scratched areas and polish out the nicks to remove any high spots or ridges, and then re-anodize. They will not be the same as "factory new", but they will look a lot better.
-David
Old 16th January 2009, 11:26 PM   #3
john65b's Avatar
I don't know if the purple color was due to heat, as you can see in the attached pic, it was a purple hue to the entire chassis.
This thing is a monster. Weighs about 65 pounds empty...
Maybe I will buff and sandblast her...
BTW - the pic is not mine...looks same with no "guts"
Old 16th January 2009, 11:56 PM   #4
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Or surface grind them, then a rebrush.
Only issue with aluminum is that it requires a grinding wheel that doesn't clogg, easiest pick would be an engine head uphaul shop.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
How to remove knicks on Krell Heatsinks/chassisHide this!Advertise here!
wtb: chassis heatsinks jtktam Swap Meet 0 3rd June 2009 01:26 PM
Retouching knicks and scratches on chassis amsci99 Tubes / Valves 2 8th May 2007 09:18 PM
Krell KSA-50 kit for sale with case/heatsinks/everything Jed Swap Meet 11 29th April 2007 06:46 PM
Chassis with heatsinks... goodlife Parts 4 9th May 2005 06:30 PM
FS: 2 chassis with heatsinks Russell Sit Swap Meet 0 7th August 2002 10:59 AM
