#11 |
Thanks Beto
what say your simulator about performance?
#12 | |
#13 |
#14 |
probably Q10 AND Q12 need resistor on collectors
like modern CFP can you post the PCB that I can order on ebay?
#15 |
#16 |
nice!
I believed that the same simulator generate design... what do you think about position of resistors 20/21? |
#17 |
R20 and R21 in the emitter because the problems in the simulation showed bias when in ultilizado collector.
may be some bug in the simulator and not 100%. Mounting the project in practice show the reality of the project |
#18 |
Beto, your schematic looks off. Look at Q13's base. Shouldn't this be connected at Q8's emitter?
- keantoken |
#19 |
Ok Keantoken the right and in turn the basis Q8 emitter.
you are correct. thanks
#20 |
You're welcome.
![]() - keantoken |
| Italian transformer needs a job... | redrabbit | Pass Labs | 1 | 14th April 2006 12:52 AM |
| New diy Forum in Italian | plovati | Everything Else | 3 | 15th October 2005 04:25 PM |
| New Italian Metal Band | Giaime | Music | 15 | 18th June 2005 02:39 PM |
| CIAO (in italian means 'HI') every DIYer, | wmincy | Introductions | 1 | 29th September 2003 04:13 AM |
