diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Noisy Amp (http://www.diyaudio.com/forums/solid-state/136482-noisy-amp.html)
vento 13th January 2009 08:15 PM
Noisy Amp
My amp makes a noise on power down (through the speakers). Anybody any ideas?
dave_gerecke 13th January 2009 08:19 PM
Hello Vento, more details would help a lot, kind of noise, make and model of amp. These will help others give you ideas as to whether it is a problem or not.
Peace,
Dave
lineup 13th January 2009 08:21 PM
This is quite normal.
And nothing to be very afraid of.
At power off the big electrolytic capacitors take some short time to dis-charge.
A way to avoid this would be to use an output relay.
This relay should immidiately disconnect speakers when OFF switch pressed.
This is probably how most commercial amplifiers do it.
Along with a delay to connect speakers at POWER ON.
To let everything get charged, settled and stable, before connect the speakers.
This will avoid any 'pop' sounds at power on.
vento 14th January 2009 10:27 AM
Thanks for your replies so far. The amp is the Music Fidelity E10 and works fine other than this problem. I had thought on the lines of capacitor discharge, but this is not a short burst of sound, it sound more like an aircraft crashing! (not joking), and lasts about 5-6 seconds.
east electronics 14th January 2009 01:04 PM
line up ......
i am very sory to say that there is no point to place an answer to a thread for the reason to just place one answer to a thread ......
i am surprized.... this is not like you at all .......
as far as i remember this amplifier does not feature a relay in the output .... i dont know the schematic but if this is some kind of trouble that occured now it might mean that during shut down your front stage comes out of balance ....
this will recuire a schematic to solve
east electronics 14th January 2009 01:12 PM
This is quite normal.this is not normal at all especially if its a problem that occured .... if amplifier is designed like that .... from starts it means that is a cheapy
And nothing to be very afraid of.if your speakers are small and high efficiency then a loud pop could cause a lot of damages if happen every day
as about adding a relay in amp like that is something that i wouldnt do ..... on the other hand solving the problem is something i would go for
lineup 14th January 2009 08:18 PM
I is more serious than I first thought.
5-6 seconds ... hmmm
If you can provide more info, somebody may figure out what is the trouble.
At least we now know what amplifier: Music Fidelity E10
Nico Ras 14th January 2009 08:56 PM
Hi Sakis,
You speak like a real technician. lets find the fault. Not lets put something to hide the fault so you dont know it is there even if it is getting worse.
Nico
Nico Ras 14th January 2009 08:59 PM
Hi Line-up,
not the answer that I would expect from a respectable audio designer.:confused:
Nico
You sound like the snake in Jungle Book -"look into my eyes and trust me, nothing will happen" :devily:
mightydub 14th January 2009 11:05 PM
Originally posted by Nico Ras
Hi Line-up,
Nico
It depends on the specifics of the design, of course, but in my experience, lineup's answer is perfectly reasonable.
Copyright 1999-2017 diyAudio
