Old 15th January 2009, 07:21 AM   #11
ostripper's Avatar
but this is not a short burst of sound, it sound more like an aircraft crashing! (not joking), and lasts about 5-6 seconds
Did it start doing this all of a sudden, or did this errata increase
gradually (over the months/years)??
OS
Old 15th January 2009, 11:09 AM   #12
vento is offline vento  United Kingdom
OS
Hi ostripper,
Can’t answer that one as it had the fault when I bought it, and was unaware of the problem.
Had a look on the net for circuit diagram, and ‘Hen’s Teeth’ spring to mind.
Old 15th January 2009, 11:20 PM   #13
nigelwright7557's Avatar
Originally posted by lineup
This is quite normal.
And nothing to be very afraid of.
At power off the big electrolytic capacitors take some short time to dis-charge.
A way to avoid this would be to use an output relay.
This relay should immidiately disconnect speakers when OFF switch pressed.
This is probably how most commercial amplifiers do it.
Along with a delay to connect speakers at POWER ON.
To let everything get charged, settled and stable, before connect the speakers.
This will avoid any 'pop' sounds at power on.
I use a microcontroller and a relay to do this.
The micro gives a 3 second delay to the relay on power up.
It also looks for looks for DC output (fault state) and disconnects the speakers if a fault state is found.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 16th January 2009, 08:45 PM   #14
Nico Ras's Avatar
I is more serious than I first thought.
5-6 seconds ... hmmm
If you can provide more info, somebody may figure out what is the trouble.
At least we now know what amplifier: Music Fidelity E10
Hi Line-up, I was joking with my comment of course.
I came across a problem many years ago on a guitar amp which may or may not be similar, but what happened was that a little while after turning power off a whistling sound came from the speaker and died down as the capacitors discharged.
The problem lay in one rail discharging quicker than the other and the amplifier became unstable as it got to some threshold voltage.
The reason for the unequal discharge was that all pilot lights were connected only to one rail of the power supply.
Nico
Noisy ADC 5th element Digital Line Level 6 30th August 2009 10:29 PM
Noisy NAD 705 squirrel69 Solid State 6 7th April 2006 01:37 AM
noisy noisy noisy noisy noisy tube dsavitsk Tubes / Valves 50 20th February 2006 04:07 PM
help on P1.7 (Noisy) pamaz Pass Labs 9 26th August 2004 02:21 PM
How can i use a noisy PSU ? Garbz Solid State 5 3rd January 2004 12:15 AM
Page generated in 0.10229 seconds (65.30% PHP - 34.70% MySQL) with 10 queries
