Soakin' up the Sound!
I just received a nice looking 2235B and fired it up. It seems to work pretty well except for a few issues. First, while in Aux mode, the right channel only works if I engage the Mono button. In Tape 1 both channels work fine. Tape two works, but it's a little scratchy. Maybe a dirty selector switch?
Secondly, the heat sink and transistors (on the right side as looking from the front) are pretty hot; too hot to touch. I turned it off for now. I'm not pushing it hard, I can talk over it in a 12 X 16 room. I'm running a pair of JBL L40's. I'm not sure how to check the DC offset or adjust it, but is that a possible cause of the heat? Finally, the string for the tuner dial is a little loose. Any ideas on that? Any other issues that might be worth checking into on this piece? Thanks in advance for any suggestions. Mike
#2 |
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#3 | ||||
Yup, sure sounds like it. Quote:
#4 |
was there ever a questionl ike "recaping or not recaping " to a 20 years old device ??????
jesus this is actually what i do for living !!!!! in the parts shop everybody wonder what i do with so many electro's i do vintage service ( together with other things ofcourse ) i can tell you one thing only ....check with a capacitor meter and you will see ... plus that often comercial amps have been kind cheapy regarding caps ....
#5 |
Excuse me sakis! You dont have to tell me. Thats precisely why I worded it the way I did and left it up to the OP to investigate. Short of restoring the damn thing I merely gave him the simple suggestions he asked for. Anybody who knows about electronics knows electrolytic have a life span. Why didn't you just tell him to restore the damn thing! Do you go ahead an recap every single unit that you get in for repair or do you SUGGEST that customer do it and explain why it should be done? Its a hard sell sometimes to customers when "essentially" their unit is working.
See what I mean with the controversial discussion?!?!?!?! |
#6 |
to e mail me and call me names big red .....
i see your aproach as a mistake any way this is a forum !!!!! i cannot advertise here my job since i am located in greece and also since the nature of the forum is like that other people cannot advertise their job also ..... so what is the wise thing to do here ????? A) explain to the person that recaping is fact B) forget posting like you did that will arrize endless questions about recaping or not ....( especially if the originial thread comes from a NB ) finally i never call forum members "costumers" but i do see them as costumers if they ever come to my shop ...... for the reckord 99% of the costumers that bring to my shop vintage amplifiers go for complete restoring and not for just a cleaning or repair of one pot ..... do want to know why ????? A) cause the amplifiers we restored in the past had amazing results and B) if you clearly and properly explain to the costumer what is going to hapen to the amplifier the 99% will go for it we make more than a living this way for years now
#7 |
You are clearly on glue sakis. Good day.
#8 | |
to you too my friend ..... have a cap of coffe and you may go as you please .....
#9 |
Wow, looks like bigred was on something more powerful than glue.. Bad day maybe
My feelings on recapping, old unit with cobwebs,nicotine,heavy dust.. discuss the economics/virtue of repair with customer. Newer 8-10 year old HT receiver...just change what is faulty, regrease OP's. OS |
#10 |
I did some adjustment on my 2235B tonight. I have all voltages where they should be according to the service manual.
I adjusted the following: Main Amp DC Offset Alignment, Idle Current, Main Amp DC Offset Readjustment, and Automatic Voltage regulator Adjustment. I have gone over everything more than once and got the voltages within spec. However, the heat-sink on the right side is still very warm; too warm to touch "comfortably." I noticed on the PS board a few of the caps look suspect. The heat-shrink is "shrunk." These are C801, 805, 807, 808, and 809. With all that said, does anyone have any ideas on what might be causing the amp to run so warm? Thanks in Advance, Mike
| Marantz 2235B Tuner Issue??? | mikje | Solid State | 11 | 6th July 2009 02:00 PM |
| running 4 ohm B&O s from 6-8 ohm marantz | conor4 | Solid State | 3 | 27th June 2008 02:47 PM |
| What advantages running ported midbass if you are running a sub? | mitchyz250f | Multi-Way | 3 | 20th May 2008 02:34 PM |
| Marantz CD80 tray motor is running non-stop | Jeph | Digital Source | 12 | 8th May 2006 02:23 PM |
| Right speakers for Marantz PM8000 + Marantz CD67-OSE? | betto80 | Multi-Way | 2 | 24th May 2005 03:21 PM |
| Page generated in 0.12184 seconds (81.08% PHP - 18.92% MySQL) with 10 queries |
