#11 | |
Hi Rob, I don't know what is common, but I'll try nearly anything to eliminate hum. I'm just using a 1/4 watt resistor as the current would be very tiny, so no worries about it heating up. Shoot, my regulators don't even get warm. I have gone through several changes and board revisions (getting quite a stack of used boards) and I'm nearly there. I have a ground plane on the bottom layer that is connected to the power supply common. This handles all of the decoupling. I then have the signal ground separated from this by the small value resistor. This picks up the shunts from the filters as well as the audio ground. I just etched and drilled board #5, ready to stuff and test. Hopefully it's a winner this time. |
#12 |
That sounds interesting. I'll have to try it.
Thank you Rob |
#13 | |||||
Ah, nothing like a morning with my harmless little post torn apart in true DIYAudio-style
Whatever you gentlemen prefer, however at least reading the full post before replying would be nice, eh? Quote:
Nevertheless, I can't resist to post a snipet of "A Practical Guide to High-Speed Printed-Circuit-Board Layout" By John Ardizzoni [analog.com] Quote:
Of course I agree that ground planes (and power planes) are necessary for RF-and digital applications (fast rising edges), however in audio I prefer a clean star-ground and the possibility to use the 2nd side for routing other signals. Now go and tell me there's a simple answer to grounding. Have fun, Hannes EDIT: found another Maxim-appnote with general advice (well, it's about cell phones...doesn't P-A work for a cell-phone company? )Quote:
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2 transistor kits |
#14 | |
I highly recommend it. I just tested the latest board and I think I have a winner. I used a ground plain on both top and bottom, as described above. Sitting out in the open (no chassis yet) I tested it with RMAA for noise level and it is below -75db. I confirmed this with Adobe Audition, recording the output without a record playing. My turntable is not on a very solid stand and it has a computer close by with a rather noisy fan going so this figure might be lower. Compare with the previous board version, I have made a serious drop in noise. The noise level of the previous version tested at -43db. |
| freaky new phonostage | Vinylsavor | Tubes / Valves | 35 | 30th November 2010 07:30 AM |
| rjm 2 tube phonostage | hacknet | Analogue Source | 6 | 10th April 2006 05:27 AM |
| phonostage design | lt cdr data | Analogue Source | 1 | 20th April 2005 09:48 AM |
| Pearl phonostage | Mark777 | Pass Labs | 0 | 6th July 2003 11:18 AM |
| diy MC-phonostage | Onvinyl | Analogue Source | 25 | 30th November 2002 04:24 PM |
