Hello, all.
I have learned quit a lot about amplifier design, recently the Frugalamp thread has been a really nice resource. I started out making a headamp, but I don't know exactly how well this will drive lower loads. It performs quite well with a 100 ohm load. Distortion (simmed) at 1V pk-pk, 100 ohms, is >.001%, throughout the audio band. Distortion at 100 ohms, 10V pk-pk at 1KHz is about .002% and at 20KHz it is about .006%. My reason for creating this thread was so that I could learn what might make my amplifier impractical. Since I've never really built a working amplifier in real life, I figure this is a good idea. D1 and Q10 form a current mirror. Since the diode and the transistor aren't matched, R8 has been adjusted to compensate. D2 and D3 improve clipping behavior. Q3 and Q4 form the bias mechanism for the output pair, acting as a voltage amplifier. No doubt this has been done before, but my inspiration came from my experiments with the Rush cascode. These transistors should be mounted on to the output transistors, for thermal tracking. I have a question: 1: If C2 goes higher than 4pF, the circuit oscillates. Is this a sign of instability, or does it indicate a healthy amplifier? Would having to use a cap this small have negative impacts on reliability (considering temperature coefficients and tolerance, etc.)? Here is the schematic: ![]() Here is the small-signal 20KHz squarewave response: ![]() Thank you for your input, - keantoken
Contribute to the DIYAudio WIKI! http://www.diyaudio.com/forums/every...p-sign-up.html LTSpice wiki with special attention to new users' troubles |
#2 |
Also, I want to know about Class A biasing, whether or not I have biased it correctly or if I can improve the biasing.
The bias is at about 150mA, enough to drive a 68-ohm load at 10V pk-pk. - keantoken
#3 |
About the 1pF - 4pF cap.
In a real amplifier such small capacitances can easily be present in the PCB tracks and wire between components. But if the amp is not 100% stable in simulations, this is a warning sign. Can be that the output, without any base stopper resistors and in sziklai configuration, can cause instability. +-12V and 150 mA Class A bias is a good value for 68 Ohms headphones. But do not increase the power/heat more if you will use MJE340/350. The bootstrap 100uF is unusual. Normally R7 would be divided into 2 resistors with the bootstrap cap connect from the output to between resistors.
lineup |
#4 | |
Hi Lineup.
I put the bootstrap cap as you described, and this brought the distortion down further! Max THD at 1.5W, 20KHz is .0017%. THD at 1KHz, 1.5W is .0004% Thank you, Lineup. - keantoken
#5 |
#6 |
I wouldn't call C1 in your first schematic a bootstrap but rather a bypass. The reason it lowers distortion so much is that the VAS is feeding into the high impendance collector of Q3 and the signal doesn't transfer very well to the collector of Q4 that feeds the lower output pair. This makes the output level from the upper and lower output pairs uneven. Bypassing Q3 and Q4 evens it up.
#7 | |
C7 works by adding OLG to further decrease the impedance between the bases of Q5 and Q6. - keantoken
#8 |
Output impedance is .1mV.
- keantoken
#9 | |
I think that's .0001 ohms, actually. Anyways, a new development if anyone's interested. I like this method better than the bootstrap, since you don't have parasitics piling up asymmetrically. As I theorized, this method would be more stable than the bootstrap. It seems I was right, as the circuit is no longer so sensitive to the value of C2 and is even stable without it at 40KHz, max output. Bias current through Q3 and Q6 will wander with temperature, but this should have no direct or significant affect on performance. This might increase PSRR, but I don't think very much since supply fluctuations will only affect quiescent current. Schematic is attached. I will have enough parts to build this sometime next week hopefully, so if it works I will post here. - keantoken
#10 |
What is the idea behind Q3 and Q6 ??
| Discrete Single End TRUE Class A HeadPhone Amplifier | lineup | Headphone Systems | 30 | 29th May 2009 09:44 PM |
| My all discrete prefilter class-D | kartino | Class D | 10 | 7th August 2006 08:47 AM |
| My 13x discrete class-D | kartino | Class D | 6 | 21st November 2005 07:44 AM |
| recommend discrete Class D | rellik | Class D | 11 | 3rd November 2005 01:27 AM |
| Page generated in 0.17477 seconds (70.02% PHP - 29.98% MySQL) with 11 queries |
