Old 9th January 2009, 02:31 PM   #1
Default Safe T0 -92 case temperature?
Hi all,
A quick question to those who would know!!
I have some TO92 PNP and NPN transistors in a circuit. Types are BC550 and 560. My case temp is about 60 deg C. Junction temp is specd in the datasheet as 150 deg C.
Are my transistors too hot? Circuit functions perfectly.
(measurements taken in the case to reflect real life use etc. - tried searching and couldn't find anything on this)
Fran
Old 9th January 2009, 02:36 PM   #2
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
It might be worth adding something like this:
http://www.rapidonline.com/Electroni...Heatsink/77178
if the dissapation can't be reduced or the transistors changed. You can get metal can (TO18?) small signal devices and some that come in a sort of tall TO92 package.
I'm afraid I don't know if that is too hot though, I have never had a circuit where such devices become noticeably warm.
Old 9th January 2009, 02:53 PM   #3
AndrewT is online now AndrewT  Scotland
Hi Woody,
what is the quiescent dissipation of your To92 devices?
What is the ambient temperature inside the closed casing?
What is the de-rating for the To92 device?
What is the peak dissipation?
Does the peak dissipation approach the de-rated dissipation?
Does the quiescent dissipation approach 50% of the de-rated dissipation?
regards Andrew T.
Old 9th January 2009, 03:21 PM   #4
Eh, thats more questions than I have answers to!!!
I'll try and answer them as best I can, but I suppose if they're not melting in front of me then they're ok!
Fran
Old 9th January 2009, 06:09 PM   #5
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
For thermal data of a TO-92 case, you can download the datasheet of an LM34DZ for example.
Looks like Sponge Bob has killed another thread.
Old 9th January 2009, 06:12 PM   #6
Originally posted by woodturner-fran
Eh, that's more questions than I have answers to!!!
quiescent device dissipation Pq = Iq * Vce.
Go and measure each device and multiply the numbers.
Come back with the results.
regards Andrew T.
Old 9th January 2009, 06:38 PM   #7
mmm 20 devices on each board. will measure a few and come back with the data. Meanwhile a search on LM39dz (see jacco's post) says the max temp for it is 100 or 110degC.
Hopefully I'll be ok at 55. Will report more later.....
Fran
Old 10th January 2009, 08:23 AM   #8
and out of the 20 off To92 devices, how many run at around 60degC?
regards Andrew T.
Old 10th January 2009, 09:19 AM   #9
all of them - some a little cooler, but not by much. but essentially all at around 50-60 or so.
Fran
Old 10th January 2009, 09:40 AM   #10
that's a lot of heat to dissipate inside this case.
20times 200mw to 300mW is going to cook everything.
Are you sure you are using the correct supply voltage?
regards Andrew T.
Max safe operating temperature for transistors inside modified factory amplifier azzajonesy Solid State 8 8th October 2008 12:00 PM
Safe operating temperature. ronjodu Chip Amps 7 31st May 2007 12:11 AM
Is it safe???? mikee55 Solid State 4 31st August 2006 10:17 AM
Hakko 936 - ESD safe vs. non-ESD safe KT Parts 2 20th June 2004 03:58 AM
Page generated in 0.35797 seconds (66.14% PHP - 33.86% MySQL) with 10 queries
