Series Caps in Power supply
Old 11th April 2003, 04:35 AM   #11
Jonathan M is offline Jonathan M  New Zealand
Default Here's the info I have:
The power amp is Rod Elliotts P68 subwoofer amplifier. It delivers 300W or thereabouts into a 4 ohm load.
It is powered using a 300VA 40-0-40 Toroid to a standard 35A bridge rectifier.
The filter caps are NEW 12000uF 50V electros (Computer grade?) that are in series to give 6000uF 100V. This is per rail.
I want to add a resistor across each cap individually to balance the voltage across them.
Assuming the that 50k will be good, that's what I'll use. I don't see the point of using a smaller resistance (It'll draw more power) unless it is of particular advantage - please advise.
Thanks for the responses so far. I've mailed Rod as well to see his views on the matter.
Jonathan
Old 11th April 2003, 04:41 AM   #12
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
The info you guys need can be found here:
http://www.evox-rifa.com/electrolyti...c_appguide.pdf
>page 4
Mads K
Old 11th April 2003, 04:58 AM   #13
Default Thanks Mad_k
Useful info.
Tells me why I haven't had any trouble yet (Worse case scenario with 20% tolerance is around 33.6V across a cap - they're rated for 50V)
Also tells me I should use 1000000/(0.015*12000) = 5k6 Ohm
resistors.
1W will easily be enough (Will only dissapate 0.15W in each resistor once everything is balanced.)
Jonathan
Old 11th April 2003, 04:59 AM   #14
nw_avphile is offline nw_avphile  United States
Default Re: WRONG AGAIN.
Originally posted by fdegrove
Where did you come from with figures?
No way to calculate any values from what's given so far here, I reckon?
Why don't you reread the thread instead of contradicting yourself over and over again in a single post?
Look at a cap datasheet fdegrove. Most manufactures give the following forumula for their DC leakage specification:
DC Leakage = .01CV
So, we take .01 * 12000E-6 * 28v and we get 3.4ma. Your method of 100k total would allow0.56ma to flow which isn't enough to balance the caps if one has say 1ma leakage and the other 3ma. My values may have been overkill, but I'd rather be safe than sorry. I don't know the age of these caps and leakage current goes up with age.
As for the power specification, do I need to explain ohms law?
And where did I contradict myself?
Old 11th April 2003, 07:49 AM   #15
If no bleeder is present you could try a pair of 50K Rs, just make sure to use equal values and that they have ample wattage for the current you're drawing..
Well I reckon that P = V**2/R. So let's see... the voltage across each resistor will be 28 volts and they're 50k ohm resistors, so 28**2 = 784 divided by 50,000 = 0.016 watts which I rounded up to 0.02 watts.
So your advice to "make sure they have ample wattage" is really out of place as it's hard to buy a resistor that won't handle 0.02 watts. So please explain the "Wrong Again" part of your subject line?
Series Caps in Power supplyHide this!Advertise here!
Powering F series amplifiers from sime power supply yoke Pass Labs 5 22nd December 2008 07:23 AM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 01:30 AM
Series power amps using a floating power supply rtarbell Solid State 6 25th February 2006 09:18 PM
power supply: shunt or series?? AudioGeek Power Supplies 34 25th July 2004 03:02 AM
