Hello Guys,
So, this is my first post, and considering the number of failed first posts I have seen in this forum I have to admit I am a little nervous. First of all I want to introduce myself, my name is Rodrigo Brunale and I am a Electronic Music Producer from Brazil. I had my first experience with music production 5 years ago in Australia and havent been able to look away since than. Considering i am only 20 years old i am still a lot to learn, not only in the Music world but in everything else in life. To be honest, I am still a virgin in the DIY world, but I am here to learn and hopefully add to this forum in the future. I have been around, reading and trying to learn as much as i can in my spare time. After a couple of months surfing this and other forums I can finally say this is the right time to ask for help. If i dont understand what you guys are saying i will say so, and ask for further explanation. I attached to this post a spec sheet for a sub i am building. My initial idea is to build an amp to drive this speaker in a 250 liters box with 2 ducts of 16cm. |
#2 |
I guess i didnt manage to get you attention, but i am sure the information i need is in this forum, i just dont know where to find it.
All i am looking for is a well documented and previous tested amp that can give me around 500 to 800 watt. And before someone say i shouldnt be trying to build an amp like this on my first attempt, i should say that i have no intention on trying to build this by myself. I just think it is easier to find help when i have the plans in my hands. |
#3 |
Hi rod, welcome to forum..
You might want to try this one... (Rod elliots project 117) You better read the whole article and don't allow children or pets around it...(link below) http://sound.westhost.com/project117.htm The amp is a ported , SUPER high power "blameless" design, very common "schoolbook" topology.. (guaranteed to work ) with a triple OP stage. One could omit 3-4 pairs of output trannies and drop the voltages to +- 100v for a modest 5-600 watts .My frugal amp can be run at +- 80 volts with 10 output devices for a good 400 watts as well. My point is you can take many DIY designs and "port " them for more/less voltage /power with just a few minor changes. the one above will cost 4-500 US dollars to build and has lethal voltages. One could refine it to sound better, but as it is, it will drive (blow) almost any driver out there... OS |
#4 |
Many of the important details have been intentionally left out of that design, to prevent idiots from getting in over their head. The "Dirty Harry" design is a lot more fleshed out and closer to being copyable. If you use 10 pair of outputs on that, it will run on +/-100V safely and give the desired power.
#5 |
And then there's this one (again). Same power as Project 117, but the details have all been worked out and I have 3 in service running off +/-127V. They should run up to +/-140 with no mods. If you strip the upper slave banks and bump up to 7 in parallel, it runs ok on +/-84V with very similar result to the Dirty Harry. I have that one running in the living room (the CS-800 clone).
For some reason the file wouldn't attach the first time. Tried again. |
#6 |
First of all i want to say thanks for all your help!
Project 117 seems under documented for my needs. But fotios's Dirty Harry seems to be a very plausible amp for me to build. I will get in contact with him and try to find out more information about his design. It might be a better idea for me to build a Class D amp, is there a well tested design around the forum? I dont know if i should open i knew post in the Class D forum or stick to this post. I am even considering ordering a Truepath or an AMP8 from 41hz. |
| 18SW1P Enclosure questions | asnn | Subwoofers | 13 | 12th January 2009 07:05 PM |
| NOS Selenium Rectifiers | Zero Cool | Swap Meet | 1 | 5th October 2008 03:45 PM |
| Selenium D4400ti | tadman | Pass Labs | 0 | 25th February 2004 10:25 AM |
| Selenium 3300TI | Jer | Multi-Way | 1 | 27th November 2003 01:51 AM |
| What does a selenium rectifier do? | Newpaltzwonder | Everything Else | 7 | 15th April 2003 01:27 PM |
| Page generated in 0.09823 seconds (75.08% PHP - 24.92% MySQL) with 11 queries |
