Old 3rd January 2009, 06:13 AM   #1
tcat is offline tcat  Australia
Send a message via MSN to tcat
Lightbulb 2 channel amp choice
what 2 channel stereo amp for home audio would you recommend? all recommendations are welcome =) also i have a set of custom made 400w rms floor standing speakers i need a 2 channel stereo amp to run them, having big trouble finding something with this power :S any recommendations for that to ?
Old 3rd January 2009, 12:26 PM   #2
are your speakers 8ohm impedance?
If yes, then look for a 100W into 8r0 amplifier that is specified to better than 160W into 4r0.
This amp will be powered by a PSU running at ~+-50Vdc and use 63Vdc capacitors. It will probably have 2pair of output devices. But 1pair of robust output devices will suffice.
If the transformer is between 100VA and 200VA with at least +-10mF of smoothing then it could be worth auditioning.
If it's a two channel amp run on a shared PSU then expect the transformer and smoothing values to be doubled.
regards Andrew T.
STK Choice metal Chip Amps 21 1st October 2010 04:48 AM
Creating 5.1 Multi Channel sound from 2 channel jenkrich Everything Else 5 1st September 2009 08:29 AM
4 channel conversion to mono 1 channel iUSERTLO72p Car Audio 24 25th October 2007 06:07 PM
HELP!: Channel volume very very low, other channel fine. harrisni Solid State 2 20th September 2006 12:10 PM
My 4 channel car Amp distorting on 1 channel (large pics) MikeHunt79 Car Audio 9 3rd September 2003 07:41 AM
Page generated in 0.07625 seconds (57.47% PHP - 42.53% MySQL) with 10 queries
