Hello experts, i need some help pls
i'd like to build a single IC based power amp for my cell phone to install it in my car, currently i need something like this: 9-14 Volt range low THD (principal usage:voice) no POP-noise on power-on power-off transitions enough power to hear weak voices in heavy traffic ways, i've been studying some datasheets basically this TDA7499SA, but my local electronics dealer doesn't have it ! any help would be very apreciated, thanks ! |
#2 |
Probably best to find out what they do have first!
You don't really need high output wattage as long as you can drive eg a 4 ohm speaker. THD also isnt too important, even 10% will be fine with voice. I'd probably go with TDA2822 in bridge mode. You could also probably get something suitable from cheap PC speakers. |
#3 |
for good intelligible voice you need 300Hz to 3kHz of frequency range. Try for a little wider if you feel the need. Maybe as wide as 200Hz to 5kHz. This range is easily met with a single driver of modest size. A 3inch or 4inch mid driver should get you to around this target. Now look for a smooth response over that frequency range and high efficiency, aim for >=93dB/2V/m for a 4ohm speaker or >=95dB/2.8V/m for an 8ohm speaker. With a high efficiency clean sounding speaker with a filtered frequency range you will not need a lot of power to compete with road and traffic noise.
regards Andrew T. |
| Help selecting a DIY amp for... | BlizzofOZ | Chip Amps | 1 | 30th April 2009 10:38 PM |
| Help selecting DIY amp for... | BlizzofOZ | Class D | 2 | 29th April 2009 04:03 PM |
| Need help selecting DAC chip | roee | Digital Source | 1 | 26th April 2004 05:55 PM |
| Help selecting an amp | FBLEAGH | Solid State | 1 | 21st September 2001 06:00 PM |
| Page generated in 0.09823 seconds (73.31% PHP - 26.69% MySQL) with 10 queries |
