#31 |
It's true!
-40degC = -40degF. What is the fluid used in a +50degC to -50degC thermometer?
regards Andrew T. |
#32 | |||
My fellow countrymen are embarrassed by my behavior sometimes so I've spared them the shame and took away my location. Quote:
![]() How's it going Nico? Having a good 2009 so far? Quote:
I'm not sure what fluid is used but the thermometer is broken now. This leads me to the conclusion that it may have been even COLDER than -36! According to the weather forecast on my email page this morning it is only -27*C today. Normal for here at this time of the year is a bit warmer. |
#33 |
I am running some tests with RMAA to evaluate (objectively) the performance of this amp.
Results soon... |
#34 |
As promised. The tests were run at about 3 watts of output power (into 8 ohms). Both channels were tested at the same time and the results are for both.
First the overall scores. Ignore the stereo crosstalk - the attenuator I use has a common ground so it invalidates that test. ![]() Next the THD: ![]() Frequency response: ![]() Noise: ![]() IMD: ![]() Not too shabby, what? I'll take it.
#35 | |
As the Pc Supply. for the transport I find it very comfortable.
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 08:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 10:52 AM |
| build or buy | navin | Multi-Way | 9 | 16th November 2004 05:36 AM |
| Page generated in 0.08925 seconds (81.66% PHP - 18.34% MySQL) with 11 queries |
