Can This Amp Be Modified??????? - diyAudio
Old 9th April 2003, 05:50 PM   #1
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
Default Can This Amp Be Modified???????
Greetings
Let be the first to say, I Know Nothing On DIY Amplifiers.
I will send this back to the manufacter, if its possible.
This amplifier consist of;
Two 2KVA Transformers
Four 17500 MFD 100V Capacitors
28 x 200 watt, 20MHZ output Transistors.
This amp is currently 350 @ 8 ohms per channel
I'm looking for 700 - 800 watts per channel. (8 ohms)
Can the Power supply handle my desired wattage?
Thanks!
OMNIFEX
Old 9th April 2003, 06:22 PM   #2
OMNIFEX,
The dominant (but not only) factor in derterminig "how much power this can amp put out" is the value of the rail voltages. The voltage level of the rails are determinded by the ratio of the primary to secondary windings of the main transformer.
Your first resonse might be, OK, I will replace the transformer with a "higher power" one. With that change you will (probably) need new diodes and filter caps.
Then you need to know if the driver portion of the amplifier can work (or even survive) on higher rail voltages.
I simple trick to find out how much an amplifier can put out, take your AC voltage (US 110v, Europe 220v etc) and multiply that by the value of the mains fuse. Example, a 7 amp fuse times 110 Volts = 770 watt amplifier AT BEST. If it is a stereo amp, divide by 2 for watts per channel, in this example 385 watts per channel.
Some on this forum will disagree with me on the issue above, but it is a very good indicator about what an amp is capable of, and no amp can put out more power than goes into it.
In short, if you want a a 700 - 800 watt amplifier, buy a 700 - 800 watt amplifier.
Now the question might be, Why do you want/need an amplifier with that much power?
Aud_Mot
Old 9th April 2003, 06:39 PM   #3
OMNIFEX's Avatar
Aud_Mot, Thank You.
So, what your saying
120 volts times two 15 amp Breakers (No fuse) = 3600
watts at best?
So what would be the average?
As for why I want a 700 - 800 watt amp.............
This amp is the lowest wattage amp I'm using,
but the of the biggest in terms of rack spaces.
(4 Rack Space)
I do alot of gigs, so, I generally Bridge it. I
figured why Bridge it, if it can get modified.
Thanks!
OMNIFEX
Old 10th April 2003, 06:40 AM   #4
OMNIFEX,
The math I presented was mainly so that you can get an idea about true RMS power. Audio amplifier manufacturers are famous for stretching the truth, or even lying and fraudulently representing their products. The AC power and fuse example gives you an idea the maximum output POSSIBLE.
No, in theory, you can get a maximum 1800 watts out of a US wall socket. You have to share the 15 amps between the 2 sockets. Plus it is common to have 2 or 3 dual sockets on the same breaker. That lamp is eating into your available 1800 watts of power.
I believe you can get a maximum 10 or 12 amps, 24 hours a day/7 days a week from a "15 amp circuit". As I recall 15 amps RMS for over an hour will trip the 15 amp circuit breaker. Plus the AC power sags during the day, call it 110 volts. Now you are down to a real world 1320 watts per circuit breaker.
The good news: Those 700 watt amplifers (assuming they are a real 700 watts) consume (on average) about 10% (maybe 20%) of that 700 watt figure. I am talking about RMS power over a period of 10 seconds to 1 minute.
But now you are getting into the can of worms how much power "is a lot of power" and how much more power do you need to have "a whole lot more power."
If I can find something on the web, I will give you a link to explain the Power Vs Loudness Vs dB's Vs Perceived Loudness.
Hint: In order for 10 watts to sound twice as loud, you need 100 watts. Yes, a factor of 10 times the power to sound 2 times as loud. Twice the power, sounds just a little louder.
Aud_Mot
Old 11th April 2003, 03:37 AM   #5
OMNIFEX's Avatar
Thank You For Your Insight On Things!
Best Regards,
OMNIFEX
TA-10.1 vs Modified SI Davet Class D 0 19th March 2007 08:05 PM
IC: Looking to get my T-Amp modified cmirza Swap Meet 0 29th May 2006 07:19 AM
ME2 modified MJS Multi-Way 7 20th October 2005 04:41 PM
modified mid-fi? amo Multi-Way 0 10th June 2003 02:21 AM
Modified ESP 3A amp. Freddie Solid State 1 26th June 2002 06:04 PM
Copyright 1999-2017 diyAudio
