Old 22nd February 2010, 07:33 AM   #101
nelsonvandal's Avatar
What CCS are used in monolithic opamps? Many of them are operational down to 1 - 1.5 V rails.
Old 22nd February 2010, 07:41 AM   #102
Matched BJT current mirror output is still within 1% at < 0.5 V--then you have 5-10 V on the other leg to make a CCS.
That's essentially what I'm doing for the input stage and current mirror CCS--just that the mirror ratios ain't unity but 4. The transistion between current mirror and CCS is actually an unsharp one. In any case the anode of D3 needs to swing ~400 mV bejond the positive rail--no active CCS could provide this unless you somehow sneak in a DC-DC converter.
The C is physically large compared to the 2 BJT options above.
In that particular case the cap needs to be rated for just 6.3 V (or even less), so the size is relatively modest. I'm more concerned that the boostrapping makes the output stage bias current a function of supply voltage and hence battery life. If we accept another 5 mA of quiescent current a zener diode might solve this.
Samuel
Old 22nd February 2010, 07:43 AM   #103
Please check the reference I've given above... The trick of working at low voltages ain't just the CCSs; you also need different input and output stage topologies.
Samuel
Old 23rd February 2010, 09:27 AM   #104
Is this what it looks like when a CCS saturates (red line)?
Old 23rd February 2010, 10:15 AM   #105
It's not really clear to me what the graph shows but if the red line plots the collector/drain current of a CCS which saturates at the positive peak of the output voltage (green line), then yes. Of course what we see here is just the onset of saturation--the 3.6 uA difference (relative to the 2.1 mA nominal current) won't make gross distortion.
Samuel
Old 23rd February 2010, 06:54 PM   #106
Uploaded a slightly revised version, link as above.
Samuel
AD797 discrete clone - comparison of seven variations tiefbassuebertr Solid State 14 9th January 2010 11:52 AM
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 02:34 PM
AD797, OPA134 or discrete buffer stage? ventle Solid State 17 12th May 2008 07:47 PM
Where can I get an AD797 Op-Amp? xanduy Swap Meet 4 29th March 2004 07:06 AM
Page generated in 0.17392 seconds (42.79% PHP - 57.21% MySQL) with 11 queries
