Old 30th December 2008, 11:15 PM   #1
yeylagh is offline yeylagh  Iran
Default what is name of this power amlifier?
hi.
do anyone know what is the name of this power amlifier?
please send me any information you have know?
Old 2nd January 2009, 06:27 AM   #2
Send a message via Yahoo to thespeakerguy
Don't recognize it. It has a very interesting output stage though. Nice symmetry.
Old 2nd January 2009, 08:45 AM   #3
This is the 60W Bipolar amp published by Elektor, designed after their Crescendo and Mini-Crescedo success. With a 35volt supply it produces 40 watts into 8 ohms and 60 watts into 4 ohms. THD is rated at 0.01%, 20Hz to 20KHz.
As per your diagram, T9/T11 and Q2/T12 should be thermally coupled. From memory I recall that P1 is a 100 ohm preset which should be set to minimum resistance at power on and increased to set Iq which can vary between 50mA and 100mA. Sounded good for the times but many of today's designs sound a lot better.
Sam
Old 2nd January 2009, 12:15 PM   #4
fotios is offline fotios  Greece
fotios's Avatar
Default From luck!
Hi yeylagh
This circuit is an exact copy of that included in the project library of EDWin XP1.xx CAD-CAE software which i use.
In EDWinXP (Visionics of India) it used for SPICE demonstration, the named EDSpice simulator.
For any query i am available as usually.
Fotios
40A 250V Schottky Power Diodes- Has anyone use in Power Amp to replace Diode Bridge? dtm1962 Solid State 10 15th September 2011 08:38 PM
smps power sg3525 for 3000 wats power alimentation MARAVILLASAUDIO Car Audio 2 24th February 2005 07:58 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 03:21 PM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
power output calculations, rated power and required power output metebalci Tubes / Valves 7 22nd February 2004 06:49 PM
Page generated in 0.10100 seconds (60.22% PHP - 39.78% MySQL) with 11 queries
