Old 30th December 2008, 05:34 AM   #1
sivan_and's Avatar
Send a message via Yahoo to sivan_and
Default High voltage Opamp with power transistors
Hello all..
I have a couple of high voltage opamps like BurrrBrown 3583JM lying around..these r capable of high voltage upto (+) & (-) 140 volts and load currents upto (+) & (-) 75ma..i am thinking of adding some transistor drivres to boost current..the idea is to use as a sub amp with an output of around 200 to 300 watts...any suggestions ?
thx in advance
SivanandBalan
Old 30th December 2008, 07:06 AM   #2
sivan_and's Avatar
http://www.electro-tech-online.com/a...put-opampb.gif
SivanandBalan
Old 30th December 2008, 08:21 AM   #3
jaycee is offline jaycee  United Kingdom
To be honest, by the time you have gone so far as to add the neccesary output stage to an opamp, you may as well have built a fully discrete power amplifier.
Old 30th December 2008, 11:03 AM   #4
sakis is offline sakis  Greece
sakis's Avatar
Default come on guys ....
there is similar applications also related with lm 12clk .....
i wonder why they exist in the books ....there is got to be a reason
all these circuits look so simple to construct so if your target is simplicity ,power and average quality i dont see any reason why not ....
i dlike to work on this a bit more
i recall the lm12 application saying 90 volts swing and +- 10 amps ... thats a hell of a lot of power .....
i thing i will have to construct to see what is going on there
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 31st December 2008, 02:31 PM   #5
sakis's Avatar
Default many people seen
this but no replies ....
its been in the forum before ....i wonder why ???
Old 31st December 2008, 02:57 PM   #6
That circuite is not a power amp. It is intended to drive a 2,000ohm load not a loudspeaker. Few people need a line
stage that will swing that kind of voltage.
Old 31st December 2008, 03:23 PM   #7
Hello,
Many years ago in the French diy magazine LED (now integrated with Electronique Pratique) there used to be a series of articles with such a design for power amplifiers. The high voltage IC directly drove one high voltage transistor or MOSFET (the ‘real’ class A, some say), which was biased by a currents source.
These designs were highly regarded for the way they sounded. On the site of Bonavolt there used to be a copy of such a design, but I did not visit it lately.
Best, Arjen.
Old 31st December 2008, 03:24 PM   #8
Juergen Knoop's Avatar
LM12 and LF357 are low voltage opamps.
How do their applications apply (LOL!) to the BB type?
Those BBs are expensive. I would sell them.
Old 31st December 2008, 03:32 PM   #9
scott wurcer's Avatar
That intermediate stage is full class B I don't think it would be too good for audio. These things are often used to drive electrostatic actuators.
2012, our time is running out.
Old 31st December 2008, 04:07 PM   #10
exactly what we used the BB for in the past. Then we switched to Apex which was cheaper.
regards
high voltage input opamp sunrise Chip Amps 7 9th April 2007 06:54 PM
high voltage transistors bocka Solid State 2 21st October 2005 07:29 AM
High voltage OPAMP / PREAMP hugeli60 Solid State 7 17th February 2002 08:03 PM
TO-3 transistors and high voltage DC ih Solid State 7 16th January 2002 11:36 AM
Page generated in 0.16804 seconds (69.38% PHP - 30.62% MySQL) with 11 queries
