I decided to set myself a challenge to fix a c-audio pulse 4x300 amplifier that was constantly in protect mode. Having replaced a control transistor and the soft start resistors in the power supply, and all 4 output transistors and the previous gain section on channel 4, I finally had a working amplifier, albeit still with some problems.
Firstly, channel 4 has a small amount of distortion added to any signal it amplfies. I took it apart again to troubleshoot this, and in the process decided to compare it to channel 4 that was previously working. Ch 3 now had no output, although the signal light was illuminated. I turned it up, and once it got to 1/4 gain, the clip light came on, yet still no sound. after much playing around, I have the following symptoms and hope someone here could point me in the right direction. Channels 1,2 and 4 amplify the signal, and do not clip with a standard signal, channel 3's clip light illuminates at very low volume, and makes no sound. When increasing signal ampilutude, both the channel with the signal and channel 3 clip, and noise is heard from channel 3 If the wire that takes the output sections signal to the board where the speakon connectors are, is removed, clipping a channel does not casue anything to happen to channel 3's clip light (it stays off) with this wire removed, channel 3 still show clipping at low gain with signal on input to ch3 No dc present on output. Any suggestions will be greatly appreciated Ollie |
#2 |
Happy New Year! Hope this helps.http://www.crownaudio.com/pdf/legacy...rvice-info.pdf
Best regards, audiomachines |
#3 |
I have reasonable experience with the Pulse amps but not the 4ch version.
The service manual is quite useful and describes the circuitry in detail. I do remember reading a bit that said that the amp should never be run with the outputs disconnected from the back panel board so be careful. The clip light on the amps is actually controlled by effectively a distortion measuring circuit so it indicates that there is something happening that the feedback loop is unable to correct for. The interaction between channels is very odd, I'm puzzled! |
#4 |
could it be a fault on the protection scheme?, all the protection of all the channels is controlled by a single chip (PIC Stamp)
HAPPY NEW YEAR! Best regards, audiomachines |
#5 |
I've never seen any problems with the microprocessor and associated circuitry on those amps. There is a lot of limiting and protection which doesn't involve the PIC. The PIC mainly controls whether the amp is allowed to run or not and doesn't have any control over the audio path.
#6 |
how about the muting, that shuts down the LTP?
| JL audio 1000/1 amplifier problem | jz23 | Car Audio | 1 | 6th April 2007 05:50 AM |
| Samson F800 Audio Amplifier Problem | gooofy | Solid State | 0 | 6th March 2007 02:30 PM |
| Speaker Workshop Pulse Response measurement problem | mightydub | Multi-Way | 0 | 10th February 2007 06:53 AM |
| your experiences with the lc audio zap-pulse modules | matjans | Class D | 8 | 25th August 2004 11:25 AM |
| Pulse transformer for digital audio | Andypairo | Swap Meet | 0 | 28th October 2003 02:50 PM |
| Page generated in 0.18958 seconds (37.38% PHP - 62.62% MySQL) with 10 queries |
