Greetings,
I was wondering if anyone here has used or heard the LC Audo ZapPulse modules. Are they truly suitable for high end audio reproduction? Does midrange and high frequency reproduction suffer? I'm sure quality of power supply construction would be a variable. Also, I've noticed that http://www.lcaudio.dk sells one version of the module for $193 US. While http://www.diycable.com sells what appears to be a different version of the module for $150 US. Any info about these modules (or alternatives) would be appreciated. Best regards, Keith |
#2 |
The one shown at DIY cable is the older version of it while the one shown on the LCaudio website is the latest one.
I haven't had the opportunity to listen to one so far. One thing that is disturbing to me is that they use a first-order filter at the output. I would feel more comfortable with a filter of 2nd order at least. Nowadys enough feedback techniques are known that would allow to even take feedback after the output filter. The newer version of the amp is using a ferrite core with a large airgap for the output coil. This will be an advantage to the first version regarding EMC. But the THD figures they state do still not look like those of a masterpiece. Though one still has to hear it to make a proper judgment. Regards Charles |
#3 |
After reading the handbook ( in Danish ) I learned that the output filter is indeed a second order. The big coil works together with an MKP cap.
I haven´t auditioned this amp myself but most customers are very plased, as I understand it, from the forums that I attend. |
#4 |
So they improved on this as well. The former documents showed only a series output inductor.
Regards Charles /who is a fan of switching amplifiers |
#5 |
I think that there are two versions of the new one as well. One is with Black Gate VK caps.
UrSv Those who say it can't be done should not stop those who are doing it. |
#6 |
Charles: To my knowledge, the cap was always there, as this is the handbook of the " old " module. The schematics they publish are very scatchy and for basic product information only as they claim to have some corporate secrets and stuff to protect. Some of the pictures of the modules on their homepage are also " treated " for the same reason.
#7 |
That would explain some things: The 80 uH coil they stated in their first "manual" would never give an upper cutoff frequency of 80 kHz into 8 Ohms that they claimed. If you add a capacitor things look different of course.
I have seen that they even made an IC unrecognizable that I assume is the driver or even a combined modulator/driver. I think that the circuit is quite straightforward and that it would be quite easy to copy (and also develop) except the PCB with vias. Regards Charles |
#8 |
Yes, it probably wouldn´t be that hard. They have a Q & A on their homepage also. Some of the customers posted quite funny black epoxy on cicuit board-questions on that board I remember.
| Optimal supply design for UCD and Zappulse modules | ewildgoose | Class D | 305 | 26th August 2008 01:24 PM |
| 2 x Zappulse 2.2SE modules for sale | Bent | Class D | 1 | 30th January 2006 05:30 PM |
| For sale: 2 x Zappulse 2.2SE Modules | Bent | Swap Meet | 10 | 29th January 2006 11:14 AM |
| ZAPpulse 2.2SE modules | mattjk | Swap Meet | 5 | 6th June 2005 04:39 AM |
| For sale: LC Audio Zappulse 2.2SE modules | m.parigi | Swap Meet | 9 | 1st March 2005 03:18 PM |
