transformer and transistor question transformer and transistor question - Page 2 - diyAudio
Old 26th December 2008, 10:49 PM   #11
plug in a bulb tester and start measuring what is going on!!!!
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th December 2008, 11:18 PM   #12
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Here is the pin out. It is different to HEXFET
Old 26th December 2008, 11:26 PM   #13
rtill is offline rtill  United States
so looking at that.... this is correct....
Old 26th December 2008, 11:55 PM   #14
that is for the 2sk1058....isn't it? (diode points toward drain)
the 2sj162 would have the diode pointing to the source...right?
Old 27th December 2008, 06:42 AM   #15
Nico Ras's Avatar
Yes that is correct. Sorry I should have pasted both. this is 2SJ162
Nico
Old 29th December 2008, 01:08 AM   #16
ok...tested my transistors with a bulb tester, all test fine.
Put in a new transformer (30-0-30 3 amp Hammond))
Put in inline 3 amp fuses and they immediately blow when turning it on. What will cause this?
Old 29th December 2008, 07:00 AM   #17
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
Andrew,
that's why I have to keep repeating that one should use a bulb tester for the start up of EVERY project and for the modification of EVERY project.
Maybe you`re gonna get the Big Bulb Award for that effort someday.
Old 29th December 2008, 08:14 AM   #18
Originally posted by Lumba Ogir
Andrew,
How does one blow a 3A fuse when using the bulb tester?
regards Andrew T.
Old 29th December 2008, 12:55 PM   #19
Nico Ras's Avatar
Could be 55W 12V car light bulbs.
rtll,
rather post your PCB layout or send it to me, it sounds as if you got something wrong.
This amp is very simple, and that could be the reason for making a mistake.
You may overlook your mistake because you have the net-list in your head and what you see is not necessarily what you think you see.
Old 29th December 2008, 12:57 PM   #20
Nico Ras's Avatar
I am curious, how did you test the transistors. Were the light on only when you biased the gate?
transformer and transistor questionHide this!Advertise here!
Transistor Question Tripmaster Chip Amps 33 10th February 2009 09:55 PM
Transistor testing question woody Solid State 0 10th October 2008 04:08 AM
The ultimate single ended class a transistor transformer?! dave_gerecke Solid State 3 8th March 2008 11:00 AM
transistor question mike49504 Car Audio 9 10th April 2007 10:59 PM
transistor circuit to replace transformer in ribbon mic? ubertar Instruments and Amps 1 14th August 2004 09:42 AM
Copyright ©1999-2017 diyAudio
