Old 22nd December 2008, 10:24 AM   #1
ECM is offline ECM  United States
Default PS Audio P500 transformer
I have a P500 regenerator I'm rewiring to 230V.
The transformer has dual primaries, but I'm not sure of the wire color codes.
I used a multimeter to check resistance between each wire and this is what I got:
Blue/black 1.3 ohms
blue/white 0.6 ohms
purple/brown 0.7 ohms
purple/gray 1.2 ohms
white/black 1.3 ohms
gray/brown 1.3 ohms
Currently, the way the transformer is connected is as follows:
Blue - Neutral line
Black- hot line
brown - hot line
white and gray connected together
purple - not used
Can anyone shed some light on this?
Old 30th January 2012, 06:09 AM   #2
Default P500
Hi ECM,
Do you fix the voltage?
which you want to to the unit of US model (input :110-120V , output 220-230V)
to the input 220-230V and out put keep the 110-120V?
Ray
Hafler P500 bkfix Solid State 0 30th March 2009 01:19 AM
Cambridge Audio C500 & P500 tom daghdha Solid State 5 12th November 2008 06:17 PM
hafler p500 rogerb Solid State 1 12th May 2007 03:30 AM
MA (massive audio) P500.1 - need Pros/Cons of their products }"{ Car Audio 0 1st July 2006 09:24 AM
Cambridge p500 ostie01 Solid State 1 18th July 2005 08:52 AM
Page generated in 0.08391 seconds (50.60% PHP - 49.40% MySQL) with 10 queries
