Marantz MR 250L backlight gone
Old 20th December 2008, 07:58 PM   #1
dayking79 is offline dayking79  United Kingdom
Default Marantz MR 250L backlight gone
Hi there,
anybody have any ideas on how to get to the backlight on a Marantz MR 250L amplifier. It has a blue illumination but mine has gone
There is no illumination at all apart from the red LED that tells you when receiving stereo from tuner section.
I think it is a fuse but it seems so difficult to get to anything behind the front panel.
Thank you.
Old 21st December 2008, 11:25 AM   #2
Mooly's Avatar
Is it like this, not that I have ever seen one. If so it's a careful, methodical strip down. Most probably a bulb, they are probably in series.
Old 21st December 2008, 02:11 PM   #3
Yes that is the one. I will have to do the big strip down thing then.
Old 22nd December 2008, 07:48 AM   #4
Mooly's Avatar
A lot of Jap gear like this should have the bulbs in sockets for replacement. Getting the correct ones may be a problem, you will have to see what is in there first.
If it is a stripdown, it's just a case of being carefull. Front off, carefully removing any knobs etc ( check for grub screws first ) and keeping a note of any different screw types.
Stuff like this usually comes apart a treat and is a good opertunity to clean it all up, the faceplate behind the glass etc.
Good luck
Marantz MR 250L backlight goneHide this!Advertise here!
