a wonderfull sziklai - Page 17 - diyAudio
Old 8th February 2009, 01:17 AM   #161
ostripper's Avatar
on ebay
Typical ripoff.. no way that amp will do 600W with only
6 of those output devices..
OS
Old 8th February 2009, 01:15 PM   #162
OS
three pair of those Sanken 200W devices will do 350W into 4ohm 60degree phase angle inside the 100ms SOAR.
and go to 600W into 2r0 inside the DC SOAR.
It will even do 960W into 1r0 but the problem will be keeping it cool at these very high currents. Low duty cycle testing with a cold heatsink.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th February 2009, 01:25 PM   #163
Stee is offline Stee  Italy
Stee's Avatar
Default power is a second quality
first is the stabilization method
a dual load on ground
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 8th February 2009, 03:10 PM   #164
east electronics's Avatar
Default Re: power is a second quality
stee...
your so called stabilization method is very well known as a sonic killer .....other amps use the same thing ( very old idea ) are very stable but sound very square....
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 9th February 2009, 07:16 PM   #165
Stee's Avatar
Default Good to know Sakis
Catalin
one idea
if driver and final on CFPhave the same devices
total gain is the same
for example if NPN have gain 50 (hFE) and PNP 100
complessive factor is same in the opposite rail
PNP 100 connect to NPN 50
this can raise job on feedback to compense this gap
and ensure stability with natural sound
(for less crossover distortion)
it's an idea not a thesys
Old 10th February 2009, 08:58 AM   #166
catalin is offline catalin  Romania
Default Re: Good to know Sakis
Catalin
one idea
Hello stee ,
I really share your ideea about mixing cfp+ef but just teoretical now.javascript:smilie('')
"if driver and final on CFPhave the same devices
total gain is the same" what do you want to say here ?
How the gain will be the same ?
Old 10th February 2009, 09:45 AM   #167
Stee's Avatar
Default Copule's Solution
I want to say that changing the position of the factors
the result does not change
hence
the complessive gain between the upper rail
are equivalent to the lower rail
if you are using components of the same rank
even though they are different (PNP and NPN hFE)
Old 10th February 2009, 06:50 PM   #168
Stee's Avatar
Default sorry wrong transistors reference
PNP driver have the same gain (hFE) of PNP final
and viceversa
Old 17th February 2009, 02:15 PM   #169
Default I'm bored
And because I'm boring .
They are some people that say without current mirror the sound is more natural .v4.4 . I will test .
Old 17th February 2009, 02:17 PM   #170
Sziklai output Moby Solid State 68 27th January 2011 11:39 AM
Hybrid Sziklai CFP Stee Solid State 0 27th December 2008 11:53 AM
ccs-loaded sziklai ionomolo Solid State 132 30th June 2008 07:39 AM
My DIY project - Wonderfull Loudspeakers ! Emeric Multi-Way 6 9th May 2008 03:38 AM
Copyright 1999-2017 diyAudio
