a wonderfull sziklai
Old 14th January 2009, 05:47 PM   #151
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
catalin,
well in that case... keep it that way.
Old 14th January 2009, 05:51 PM   #152
catalin is offline catalin  Romania
And the problem is solved by chosing with atention the resistor in the mirror(220),the resistor in input vas(2.2k) and the negative feedback from the emitter vas(75 ohms) .
Old 14th January 2009, 05:53 PM   #153
homemodder is offline homemodder  Portugal
Catalin the designs in that thread especially the first 2 are exactly what you have, taking away the cascodes.
You going to play a lot around with values, keep in mind that real transistors have do not match so well compared to simmed ones.
If this type of biasing worked we would have already seen thousands of amps using it, look at the date of that thread 2003, there are threads even earlier than this.
Old 14th January 2009, 06:16 PM   #154
Originally posted by Lumba Ogir
catalin,
Lumba, even with the simetrical amp the open loop to 20khz is still 65db
Old 14th January 2009, 06:46 PM   #155
For everyone ,I just simulate most defavorable case ...
One of the input transistor with a beta common-100.
The dc output is increasing with 30mV from the original (200uV) .
Old 14th January 2009, 07:23 PM   #156
Banned
catalin,
we should leave it hanging.
Old 14th January 2009, 08:20 PM   #157
Stee is offline Stee  Italy
Stee's Avatar
Default can i say one idea?
about crossover distortion...
put a mix of CFP and EF
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 7th February 2009, 10:55 AM   #158
Default Let's discuss a little abot Current feedback !
Let's discuss a little about current feedback amps .
I obtain with this circuit :
Slew rate 200V/uS . Phase margin > 70 degrees .Thd 0.0001 % .Open loop gain 137 db ; 90db at 20khz !
Bandwith 22mhz without input filter .
What disadvantages ant what advantages it brings ?
I think that the stability is one problem .
What do you think ?
Old 7th February 2009, 02:46 PM   #159
Stee's Avatar
Default very intresting Catalin
if Q88 is 2SA1302 maybe more stable
because in CFP OS --> hFE paramenter is foundamental
between complementary in common collectors
also
have just one point to drive Output Stage... see figure
can improve stability because front-end have a common load
Old 7th February 2009, 08:50 PM   #160
Stee's Avatar
Default see this circuit
on ebay
http://stores.ebay.it/Blekok-Ham-and...Parts-Kits-DIY
a wonderfull sziklaiHide this!Advertise here!
Sziklai output Moby Solid State 68 27th January 2011 10:39 AM
Hybrid Sziklai CFP Stee Solid State 0 27th December 2008 10:53 AM
ccs-loaded sziklai ionomolo Solid State 132 30th June 2008 06:39 AM
My DIY project - Wonderfull Loudspeakers ! Emeric Multi-Way 6 9th May 2008 02:38 AM
