a wonderfull sziklai - Page 15 - diyAudio
Old 14th January 2009, 05:32 PM   #141
Banned
I would not make the voltage amplifying section complementary symmetrical.
Old 14th January 2009, 05:41 PM   #142
catalin is offline catalin  Romania
Originally posted by AndrewT
C32 is too small.
It needs to be >= 22k/680r * sqrt(2) * 4u7F >= 215uF. Use 220uF.
C42 seems a bit big @ 47pF
R = 150 at output also seems big, only 8mA passing Q60 & 51.
Does the mirror load on the LTPs work when you have dual complementary VAS?
The 100 uF(still think that 47u is good) comes from low frequency ~5hz(not audible) => f=1/(2*3.14*R*C) ;= 0.16/(680*C);;;C=0.16/(f*R)=0.16/(680*47u)=5 hz.
C42 is calculated to minimise the noise band > pole at 154khz.(0.16/(22k*f)
Q60 and q51 working at 1mA ! not 8 . 2sc5171/1930 is working at 8-10ma. big input impedance for not oveloading vas => small thd . about the mirror ltp ...look at stochino's amp !
Old 14th January 2009, 05:46 PM   #143
Originally posted by roender
Catalin,
May I suggest you to not reference CCS's biasing resistors to ground?
Try to make the input stage + VAS as much as possible a constant current compound stage.
Keep the ground as clean as possible and use a separated PSU for output stage, and for inputs stages a good ccs+shunt feedbackless PSU
Mihai
An capacitor + another R to ground will be better ? or do you want to say something else ?
Thanks !
Old 14th January 2009, 05:48 PM   #144
Can you explain why?
Thank you
Old 14th January 2009, 05:52 PM   #145
Catalin, you are absolutely right about stochinos amp, but look more carefully and youll see why his vas looks the way it does. He was clever and found a way to define the vas current, try define it on your design.
In your case the mirror you hae there will help but i dont think it will overcome the problem completly
Old 14th January 2009, 06:10 PM   #146
"output offset will be all over the place,"
Explain pls
Thank you
Old 14th January 2009, 06:27 PM   #147
Banned
catalin,
for a more favorable distortion pattern. Then I would use the resources to linearize the open-loop.
Old 14th January 2009, 06:32 PM   #148
Here is some info by members with much more theory knowledge than me and some diffrent ways to look at the problem. Theres many more threads I can refer to. The Jlh solution works but it has some flaws too, read the whole thread.
Unstable VAS current in amp from Slone book
Old 14th January 2009, 06:34 PM   #149
catalin,
I think that distortion is less(crossover,pozitive and negative rail have their way,etc,) with complementary design and a lot other advantages .
Old 14th January 2009, 06:46 PM   #150
It' not like his problems.
In that design the current vas don't change with the vcc.just one aspect
Sziklai output Moby Solid State 68 27th January 2011 11:39 AM
Hybrid Sziklai CFP Stee Solid State 0 27th December 2008 11:53 AM
ccs-loaded sziklai ionomolo Solid State 132 30th June 2008 07:39 AM
My DIY project - Wonderfull Loudspeakers ! Emeric Multi-Way 6 9th May 2008 03:38 AM
Copyright 1999-2017 diyAudio
