#131 |
Banned
homemodder,
I comprehend. The turn-off "artifact" is well-known, can be cured by class A biasing only. Many buoyant attempts have been made to get rid of the unpleasant crossover distortion in other ways, unfortunately, I don`t think it`s possible. |
#132 |
Cant get rid of, but can be significantly reduced, Im trying something similar now with a triple but its more tricky here because of stability problems.
Do you mean having the cfp in class a ?? I already use the cfp in class a. Look at stee s example of cfp ef. What I dont like is the extra complexity to achieve this but it has good sonic merits, when I remove the extra circuitry the human voices seem to have like a glare at the end of a sung word and with it it dissapears, cymbals become very detailed with the extra circuitry too. When listening at 200 300 watt levels the crossover artifacts sound horrible. |
#133 | ||
Banned
#134 |
The turn-off "artifact" is well-known, can be cured by compensation biasing only
this resistor's value are not simulated, just for example (I'm not able to use)
#135 |
at least that some forum members are
solid rock value !!!!! the ratio as we speak remains ..... one post one schematic !!!!! way to go stee !!! i am just jocking but i think that if i ever had the time to analyze all schematics posted by stee it will take something like a year ... thanks people
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#136 |
not have time for practical testing .
Thd (5khz) with 5 harm =0.0002 % Slew rate = 250 V/uS |
#137 |
C32 is too small.
It needs to be >= 22k/680r * sqrt(2) * 4u7F >= 215uF. Use 220uF. C42 seems a bit big @ 47pF R = 150 at output also seems big, only 8mA passing Q60 & 51. Does the mirror load on the LTPs work when you have dual complementary VAS? |
#138 | |
May I suggest you to not reference CCS's biasing resistors to ground? Try to make the input stage + VAS as much as possible a constant current compound stage. Keep the ground as clean as possible and use a separated PSU for output stage, and for inputs stages a good ccs+shunt feedbackless PSU Regards, Mihai |
#139 | |
Nope, only in simulation, I hope no one tries to build it, output offset will be all over the place, the current mirror issue with complementary ltps has been discussed many times, rather try a cascode on the ltps. Do a search here of randy slones designs. He eventually had to change his current mirror designs because of this. |
#140 | |
Andrew ,where do you get that calculation (>= 22k/680r * sqrt(2) * 4u7F ) ? |
| Sziklai output | Moby | Solid State | 68 | 27th January 2011 10:39 AM |
| Hybrid Sziklai CFP | Stee | Solid State | 0 | 27th December 2008 10:53 AM |
| ccs-loaded sziklai | ionomolo | Solid State | 132 | 30th June 2008 06:39 AM |
| My DIY project - Wonderfull Loudspeakers ! | Emeric | Multi-Way | 6 | 9th May 2008 02:38 AM |
