a wonderfull sziklai
Old 9th January 2009, 11:25 AM   #121
homemodder is offline homemodder  Portugal
Yep kinda dangerous if a newby tried some of them at typical amp voltages . I did this when I was 10 or so, still have a little dent on my face just below my eye for my ill concieved experiments from a plastic bjt that went boom.
Im grateful for my eye.
Old 9th January 2009, 02:48 PM   #122
Stee is offline Stee  Italy
Stee's Avatar
Default quote
Originally posted by homemodder
Plenty current can be flowed, if I can give you one reference look at eletrocompaniet outputstages, theres something they do very well, loads and loads of powerful clean bass. I have 2 nemo s and 2 aw250 amps, for bass I havent heard any amp of any price be better at low frequencies.
I can supply a schem if you want to have a look.
Hi homemodder can you shere this schematic?
AndrewT
I apologize if you find irritating my architectures stop propose
no problem
yes the value of this load resistor is wrong, but this idea is beatiful
Please download my best audio idea https://www.facebook.com/DiyAudioHiEnd
Old 9th January 2009, 02:59 PM   #123
R.I.P.
Default Re: quote
who's idea is beautiful?
and why did you change it to something that probably can never be made to operate?
regards Andrew T.
Old 9th January 2009, 07:39 PM   #124
Stee's Avatar
Default Just an idea to found better solution
I would like use CFP configuration on my Amp
because his speed produce an intresting sound
so i have tested some solution
but CFP when works with power is very unstable
sometime generate RF
now I would like found a Simply solution
for example use this stage as driver
it's a beautiful idea
because his devices are little
so more similar, so more stable
but now generate a clipping:
probably because need an indipendent load (see figure)
( I am only a hypothesis )
or viceversa
need a common load between two rails... (next step of evaluation if that before fault)
again sorry for my english
Old 9th January 2009, 09:00 PM   #125
Stee if you want the schematic, email me, its too large for pacing here and if I shrink it, you wont see whats on it.
Old 9th January 2009, 09:10 PM   #126
Stee's Avatar
Default Common load hypothesis
very approximate value
new architecture is subject to change
please edit if you like
Old 9th January 2009, 11:20 PM   #127
Stee's Avatar
Default separate rail load
thanks Alex
Old 10th January 2009, 08:08 AM   #128
east electronics is offline east electronics  Greece
east electronics's Avatar
Default Re: separate rail load
thanks Alex
stee ....it seems that you dont get it !!! do you ????
this is almost thread jacking ...and also forum people dont have the time for this ...... in only one thread you posted almost 15 schematics .....
this is a thread to disscuss
JOY 200 AMPLIFIER MADE BY CATALIN
so please give us a brake
regards sakis ( with sexy avatar )
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 13th January 2009, 10:37 AM   #129
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
homemodder,
how have you improved CFP crossover artifacts?
Old 13th January 2009, 11:22 AM   #130
I use cfp only as driver in a EF, their is a way to reduce high frequency distortion and crossover artifacts of this arrangement but I cannot discuss it as I use this arrangement in a amp I sell to car audio and as a PA amp. I will only say it isnt sliding bias or error correction, its effects are mainly seen at high powers and at higher frequencies 1 KHZ and above. Its very simple, anyone can come up with this idea if he spends some time studying what happens in the circuit. A performance graph is on the fruga amp thread, I go for very low thd as my amps are for use at powers of 250 watt or more and need to have as little nasties as possible in high frequency domain.
a wonderfull sziklaiHide this!Advertise here!
Sziklai output Moby Solid State 68 27th January 2011 10:39 AM
Hybrid Sziklai CFP Stee Solid State 0 27th December 2008 10:53 AM
ccs-loaded sziklai ionomolo Solid State 132 30th June 2008 06:39 AM
My DIY project - Wonderfull Loudspeakers ! Emeric Multi-Way 6 9th May 2008 02:38 AM
