Old 5th January 2009, 09:11 AM   #101
Stee is offline Stee  Italy
Stee's Avatar
Default another example
with Hexfet and OPA 604
Please download my best audio idea http://www.esafono.it/ISY.zip
Old 6th January 2009, 09:49 AM   #102
catalin is offline catalin  Romania
Default simply
Joy 200 v4 .Testing ...
Slew rate 150V/uS ,Thd(Pout>20W,1khz-20khz,5 harm) =0.0003%
here have been improvements: the thermal regime, phase reserve, THD, slew
rate, TID, the driver failure, etc.
Outputs is still enjoying the benefits of sziklai .
Old 6th January 2009, 11:09 AM   #103
Stee's Avatar
Default Catalin you are a genius
can put a pair of FETs on input?
do you sell PCB on EBay?
see this
http://www.amb.org/audio/beta22/
Old 6th January 2009, 12:20 PM   #104
Yes Stee you can put a pair of fet and remove the 2*100ohms resistor.
I change the 2*10pF into 12pF,18pF
Old 6th January 2009, 12:31 PM   #105
sakis is offline sakis  Greece
sakis's Avatar
Default thanks catalin
for still working with the wonderfull sziklai and also its very welcome and nice to see updates and improovements
thank you
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 6th January 2009, 06:36 PM   #106
Stee's Avatar
Default Wonderfull Sziklai Driver
see version 5
Old 6th January 2009, 06:43 PM   #107
PMA is offline PMA  Europe
PMA's Avatar
My 12 cents to Sziklai, one channel class A out-of-FBloop output stage:
Old 6th January 2009, 07:43 PM   #108
Stee last year I was 2 times in Milan. I still don't belive that is better to get rid with 47uF capacitor.The error voltage (in output ) will be splited by 22k/680 so in dc the V offset will be bigger(volts).
Old 6th January 2009, 07:44 PM   #109
Stee's Avatar
Default PMA you are a GURU
can we know more about your CFP amp?
Catalin
in my amp I always delete DC offset CAP
drift maximum 0.4V
sound much better
when you are here can listen
Old 6th January 2009, 07:48 PM   #110
The error voltage(dc offset) will compare the output voltage by a factor of 22k/680 since in output we don't have an voltage divider.Pls show your schematic
Sziklai output Moby Solid State 68 27th January 2011 10:39 AM
Hybrid Sziklai CFP Stee Solid State 0 27th December 2008 10:53 AM
ccs-loaded sziklai ionomolo Solid State 132 30th June 2008 06:39 AM
My DIY project - Wonderfull Loudspeakers ! Emeric Multi-Way 6 9th May 2008 02:38 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
