from NICO design an idea to have perfect balanced VAS rails need an output stage it's coming from my lab a modern CFP with mosfet driver
visit my best audio idea http://www.esafono.it/DACTONE.htm |
#2 | |
Kind regards Nico |
#3 |
Questo va molto benne! This is something we all like. Scientists studying genetics and human behavior have discovered the base of beauty is simetry...not the perfect simetry, but the non hardly assimetrical faces. Seems stable...ballanced... simetrical things, if we put them to float into the ocean, it will not sink...front part will not be heavier than the opposite part... ballanced. Unfortunattely, i have found those last long decades building amplifiers, that is very hard to find PNP and NPN matched devices... this result those designs are applied into chip amplifiers, they have technology to ballance the units inside the same metal waffer. Beautifull, has sex appeal, seduction, looks nice...your amplifiers are very interesting fratello. arrivederci Carlo
Try to build an amplifier folks ... it is pure adrenaline! |
#4 |
hi nico
can you redesign this schematic with 2sk1058 |
#5 | |
what you have done will work. Gate resistors 470 ohms. Keeping in mind that it will be class A so start with small supply so you first get the feel for heat. But let us wait for Steve, I think he is going to make something special. I hope he turns this into a project. Hi Carlos, thanks for the compliment. This is a working amplifier. I am not such a perfectionism as you and I seldom worry about matching device gains. This amp works extremely well with even simple transistors. Kindest regards Nico |
#6 |
Thank you very much Brothers
I hope this research can produce great satisfaction indeed difficult to find complementary in the world of human for example i have match 2SA1302 with 2SC5200 (!) 2SK216 and 2SJ79 it's possible find togheter on ebay also for NTE 36/37 12A 100W this important experiment can produce an excellent result only if you use true similar copule (10%) see the CMP
| Different pre amp idea | bartek | Solid State | 3 | 25th March 2008 03:42 PM |
| I really have no idea what I'm doing here... | d to the g | Multi-Way | 10 | 7th March 2008 06:04 PM |
| P.S idea | noyan | Power Supplies | 15 | 19th December 2007 08:50 PM |
| An idea! Fully balanced TDA1541A DAC idea. Please comment! | cartman | Digital Source | 8 | 17th July 2007 08:18 AM |
| Page generated in 0.11286 seconds (77.36% PHP - 22.64% MySQL) with 11 queries |
