diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Triple emmiter follower (http://www.diyaudio.com/forums/solid-state/135031-triple-emmiter-follower.html)
bogdan_borko 17th December 2008 02:51 PM
Hi, I am exploring bjt buffer output stage using MicroCap. There is a problem (at least in simulation) when output is cap-loaded. Input of the driver is loaded with +/-30V 10KHz rise and fall time 100nS.
I attached the schematic and output signal when loaded with 100nF and 2uF. (I used MJL model by Andy C)
Is this simulation problem real and could this be fixed without using output coil ,zobel and feedback?
Thanks.
Borko.
bogdan_borko 17th December 2008 02:52 PM
2 Attachment(s)
schematic:
bogdan_borko 17th December 2008 02:55 PM
2 Attachment(s)
100nF-8-Ohm-load:
bogdan_borko 17th December 2008 02:57 PM
2 Attachment(s)
2uF-8-Ohm-load:
Nico Ras 17th December 2008 03:02 PM
Originally posted by bogdan_borko
2uF-8-Ohm-load:
hi Bogdan,
send me your .cir and I will play with it as well. I use MC9. My e-mail is nico_ras@telkomsa.net
Nico
bogdan_borko 17th December 2008 03:07 PM
Originally posted by Nico Ras
hi Bogdan,
Nico
The file i sent.
Cheers!
Bonsai 17th December 2008 03:14 PM
I have not seen this in practice on a square wave.
However, on a number of amps I've designed and built, on a10-15Khz sine wave output, I got 'ringing' at 100Khz and higher on the final 90 degree quadrant (so as the sine wave comes off the negative pk voltage and heads towards 0V.
In these cases the cause is almost always parasitic oscillation in the output stage. Additionally, if your amp has a 'sticky' problem, this can make the situation worse on output voltages that swing close to the rails, but don't quite clip. ('sticky is when the amp sticks to the rails when overdriven - i.e does not recover cleanly)
A few things to fix it:-
1. Use a Zobel directly on the output before the output inductor (10Ohms + 0.1uF)
2. Use a 100 Ohm in series with the pre-driver base transistors from the VAS
3. In really stubborn cases, I use a 27 ohm in series with the the positive driver base and the negative driver base. From each driver base, I put 1nF 1kV capacitor to 0V.
Parasitic oscillation in triples is a common problem - in fact, Microcap even published an ap note on this issue and how to cure it (sorry, I do not have it anymore) - this is where I got the 27 ohm and 1nF cap solution from (they used different values - I got mine from trying it practically).
Good luck
lineup 17th December 2008 03:40 PM
2 Attachment(s)
Bonsai
Why settle for Tripple ;)
When you can try the brand new
Lineup Quattro Output Stage
.. just invented :cool:
high gain super plus!!!!
Nico Ras 17th December 2008 03:56 PM
Originally posted by lineup
Bonsai
Hi Lineup.
Very interesting "invention", I would like to try this. Have time to kill.
Nico
Nico Ras 17th December 2008 04:21 PM
Bonsai
NOPE :whazzat: got to think this one through a little.
Copyright 1999-2017 diyAudio
